Since this FC has inverted circuit for both sbus and S. Port, you don't need the hack s. Port. So blue wire is incorrect. You just need normal s. Port signal from the RX. The red, black and yellow wire are correct.
First thing you need to do is bind to qx7. Watch a YouTube video. Basically get TX into bind mode and hold down bind button on RX and plug in battery. Get out of bind mode, unplug and plug battery back in. Green light in RX means you bound.
OSD is a different issue, why don't we work on one issue at a time?
How can I have rssi working please? I have it on the osd but not working. I see that i can mod the x4rsb and wire it but where should I plug it on the fc? A free uart? Thank you for your time
Are you referring to the S. Port wire? You need to wire S. Port telemetry and get that working first. So, non-hack S. Port to 4T on FC. Makes sure you config BFC.
(26-Jun-2018, 03:44 PM)voodoo614 Wrote: Are you referring to the S. Port wire? You need to wire S. Port telemetry and get that working first. So, non-hack S. Port to 4T on FC. Makes sure you config BFC.
Sorry i dont understand. What you mean please? I was refering to this mod:
