13-Dec-2022, 10:31 PM (This post was last modified: 13-Dec-2022, 11:03 PM by Zorik_IL.)
Hi, I found some issue with flashing process. After the new firmware was successfully updated, there is no window 'Apply defaults defaults'. Here is a short video
Build 4.3.2 and hex file (loaded manually . needed for ELRS 3)
# vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 LOWRACE L FACTORY 5333 5373 5413 5453 5493 5533 5573 5613 vtxtable powerlevels 5 vtxtable powervalues 10 2 14 20 26 vtxtable powerlabels 0 RCE 25 100 400
# master set gyro_lpf1_static_hz = 0 set gyro_lpf2_static_hz = 0 set gyro_lpf1_dyn_min_hz = 300 set gyro_lpf1_dyn_max_hz = 550 set acc_calibration = 13,-81,8,1 set rx_spi_bus = 3 set blackbox_device = SPIFLASH set dshot_idle_value = 1200 set dshot_burst = AUTO set motor_pwm_protocol = DSHOT300 set motor_poles = 12 set vbat_max_cell_voltage = 440 set vbat_min_cell_voltage = 290 set vbat_warning_cell_voltage = 310 set current_meter = ADC set battery_meter = ADC set ibata_scale = 470 set beeper_inversion = ON set beeper_od = OFF set yaw_motors_reversed = ON set small_angle = 180 set deadband = 1 set yaw_deadband = 1 set pid_process_denom = 4 set simplified_gyro_filter = OFF set osd_warn_batt_not_full = OFF set osd_warn_batt_warning = OFF set osd_warn_esc_fail = OFF set osd_warn_core_temp = OFF set osd_rssi_pos = 314 set osd_link_quality_pos = 2392 set osd_rssi_dbm_pos = 2360 set osd_tim_2_pos = 2433 set osd_flymode_pos = 2457 set osd_throttle_pos = 2425 set osd_vtx_channel_pos = 2305 set osd_current_pos = 2336 set osd_mah_drawn_pos = 2368 set osd_craft_name_pos = 2442 set osd_warnings_pos = 2345 set osd_avg_cell_voltage_pos = 2401 set osd_disarmed_pos = 2314 set osd_esc_rpm_pos = 161 set osd_core_temp_pos = 2328 set osd_stat_tim_1 = ON set osd_stat_max_spd = OFF set osd_stat_battery = ON set osd_stat_bbox = OFF set osd_stat_bb_no = OFF set system_hse_mhz = 8 set debug_mode = RX_EXPRESSLRS_SPI set vtx_band = 3 set vtx_channel = 2 set vtx_power = 5 set vtx_low_power_disarm = ON set vtx_freq = 5685 set max7456_spi_bus = 2 set pinio_box = 40,41,255,255 set flash_spi_bus = 2 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_sensor_align = CW90 set gyro_1_align_yaw = 900 set expresslrs_uid = 222,65,54,243,28,227 set expresslrs_rate_index = 1 set name = Mobula7 1S
# profile 0 set dterm_lpf1_static_hz = 0 set vbat_sag_compensation = 100 set anti_gravity_gain = 4500 set iterm_relax_cutoff = 20 set yaw_lowpass_hz = 0 set p_pitch = 80 set i_pitch = 25 set d_pitch = 80 set f_pitch = 100 set p_roll = 80 set i_roll = 25 set d_roll = 80 set f_roll = 100 set p_yaw = 90 set i_yaw = 90 set f_yaw = 100 set d_max_advance = 0 set feedforward_jitter_factor = 5 set feedforward_boost = 18 set feedforward_max_rate_limit = 95 set simplified_master_multiplier = 145 set simplified_i_gain = 65 set simplified_d_gain = 185 set simplified_pi_gain = 190 set simplified_dmax_gain = 0 set simplified_feedforward_gain = 130 set simplified_pitch_d_gain = 85 set simplified_pitch_pi_gain = 90
profile 1
profile 2
# restore original profile selection profile 0
rateprofile 1
rateprofile 2
# rateprofile 2 set rates_type = BETAFLIGHT set roll_rc_rate = 110 set pitch_rc_rate = 110 set yaw_rc_rate = 100 set roll_srate = 75 set pitch_srate = 75 set yaw_srate = 70 set tpa_breakpoint = 1250
rateprofile 3
rateprofile 4
rateprofile 5
# restore original rateprofile selection rateprofile 2
14-Dec-2022, 04:48 PM (This post was last modified: 14-Dec-2022, 09:20 PM by Zorik_IL.)
Issue solved, I got support from the 'happymodel' team: This is what they told me to (2 files attached) Just roll back the firmware to 4.3.1 and then load the default factory setting, i have attached all .
