mixed motor kv?
Hi there,
One of my motors died and the spares I have are a different kv. Currently on the quad :diatone mamba 1105x 5000kv; the spares I have are Betafpv 1105x 6000kv. I'll be powering them on 3s (it's a 3inch toothpick). What would be the repercussions of such a match, if any?
1105x 5000kv vs 1105x 6000kv is not that huge a difference.
If you have bi-directional dshot then hopefully the code can compensate for the differences in RPM.
I will suggest you give it a quick try. You will immediately know how the quad behaves but my educated guess is that it will be just fine.
Yes, u can have different KV motors, remember u will be limited to the lowest KV.
(29-Mar-2022, 07:21 AM)kafie1980 Wrote: 1105x 5000kv vs 1105x 6000kv is not that huge a difference.
Thanks!
(29-Mar-2022, 10:34 AM)Rob Axel Wrote: Yes, u can have different KV motors, remember u will be limited to the lowest KV.
Thanks for responding. So you're saying the other 3 motors will perform on the same level as the odd one?
The other 3 motors should be close enough in terms of performance that the FC should be able to adjust for the variations in RPM during flight.
(29-Mar-2022, 09:59 PM)kafie1980 Wrote: The other 3 motors should be close enough in terms of performance that the FC should be able to adjust for the variations in RPM during flight.
Thanks again!
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 2 147 28-Apr-2024, 02:58 PM
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 0 77 23-Apr-2024, 09:36 PM
Last Post: rr240
  Sometimes a motor surprises you - in a good way mstc 20 878 10-Apr-2024, 09:00 PM
  Help Brother Hobby Motor VY1507 hawk01 3 136 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 1,088 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
