Micro won't arm
So I now have the receiver connected and showing in betaflight, but can't seem to figure out why it won't arm.  I set the arm mode and made sure it is on the correct AUX, but normally when everything is correct I can see it change color.  Any ideas?
Thank you in advance for your help.  Big Grin
It was the calibration!  Chalk up another win for intofpv!!!!
Is the quad level when you try to arm? Have you calibrated the accelerometer? Are there any warnings showing in the configurator? Did you press 'Save'?
More info is needed!
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 601 23-Apr-2024, 08:08 PM
Last Post: segler999
  Help [HELP NEEDED] Shorted something out, and now the drone won't connect to the PC ericrcrain 9 369 16-Feb-2024, 10:41 AM
  Help Micro Quad flying easy but wobbling Harry1 46 1,409 13-Feb-2024, 10:18 PM
  Help My Meteor85 won’t fly SimonFPV 18 1,407 05-Sep-2023, 05:30 PM
Last Post: SimonFPV
  AXII 2 Micro 20mm antenna fit in Mob6? dwije21 8 409 27-Aug-2023, 03:30 AM
Last Post: brettbrandon
