Mamba F722S camera control
I’ve setup camera control using OSD pin on an HGLRC F7 and Matek F7 FCs. I just got a Mamba F722S and it says camera control is available and in BF it is mapped to pin B08. But there is no pad labeled camera control and their [limited] documentation makes no reference to that pad.
Has anyone successfully setup camera control on Mamba F7 FC using OSD pin? I can always buy a new camera that has the tx/rx vs OSD/GND but I have a new camera (RC swift 2) that I would like to use and avoid having to buy a new camera.
Thanks in advance!
Jeff
Just because the resource was assigned in BF, that does not mean there is a breakout pad. If you don't see it, then you will just have to remap an used pin like PPM for camera control.
(18-Apr-2020, 01:34 AM)voodoo614 Wrote: Just because the resource was assigned in BF, that does not mean there is a breakout pad. If you don't see it, then you will just have to remap an used pin like PPM for camera control.
Ok. That makes sense. I have a inquiry into their support. If I don’t hear back I will remap the resource.
Thanks
Jeff
(18-Apr-2020, 02:26 AM)jforhan Wrote: Ok. That makes sense. I have a inquiry into their support. If I don’t hear back I will remap the resource.
Thanks
Jeff
Hey there, did they ever respond?
  Mamba Mk5 F435 Stack - Anyone running one? Pathfinder075 7 656 18-Apr-2024, 02:55 PM
Last Post: punkkone
  Discussion Servo Control Supply DroneSpyder 2 130 11-Feb-2024, 07:18 PM
Photo Help Mamba F405 Motor 3 not working when LED added Toppers 20 3,645 01-Nov-2023, 10:21 PM
Last Post: onesimos
  Diatone Mamba MK4 F740 AIO - F722 BASIC FC + 40A good? OnkFPV 2 488 29-Sep-2023, 10:53 AM
Last Post: Sleepycbr
  Mamba 411 16x16 Full UART for CRSF CLI jasc 35 9,567 23-Sep-2023, 10:41 PM
Last Post: GSixx8
