Threads: 6
Likes Received: 0 in 0 posts
Likes Given: 2
0 28-Feb-2023, 05:54 PM (This post was last modified: 21-Mar-2023, 05:06 PM by sorgloserfalke1.) hi been flying for a bit but new to elrs. Im using dji goggles v1 and a tx16s internal elrs i have setup wtffpv full os and it works but doesnt show LQ for some reason, any idea why?
edit: i found out what the problem was for some reason it cut off a bit from the bottom of the screen
Threads: 583
Likes Received: 8,955 in 6,626 posts
Likes Given: 1,425
786 It might sound like a stupid question but you have enabled the LQ element in the OSD tab of Betaflight Configurator haven't you? And you have positioned the LQ element in the virtual OSD area on that tab haven't you?
Do you see an "LQ" icon on the screen or just nothing at all for the LQ icon or value?
Are you seeing any other Betaflight specific OSD elements on the screen?
It might be helpful if you can run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 In addition to posting the CLI dump Snow requested, confirm that you do not have RSSI_ADC checked on the receiver tab in Betaflight and that RSSI Channel is set to disabled.
