Long awaited Brushed F3 FC with build-in FrSky SBUS Rx
Long awaited FC is almost here guys. It has what we all requested so someone out there heard us and is giving it to us Big Grin
http://www.banggood.com/Eachine-FRF3_EVO...91779.html
First of all the dimensions are very close to a SciSky (Quanum Pico) and same as previous ones Fc's that are currently in BG from Eachine.
Build in Frsky Rx SBUS ACCST protocol.
Build in telemetry on VBAT (finally)!
A buzzer port.
LED port.
You will need to setup your Taranis model with D8 mode X9D for the channels. I don't know if they meant PPM protocol as all PPM Rx's in FrSky is usually in D8 mode.
Features
  • Size: 33mm x 20mm x 4mm
  • Weight: 2g
  • CPU: STM32F303 72Mhz
  • Gyro + Accelerometer: MPU6500
  • Working Voltage: 3.7v Range (3.3v - 4.2v)
  • Receiver: FRSKY 8CH SBUS protocol
  • Compatible Tx: FrSky X9D/X9D PLUS (D8 Mode) XJT, DJT, DFT, DHT
  • Channel Map: TAER1234
  • Default Unlock Channel: AUX1 (Channel 5)
[Image: ce83136c-3bd9-47c8-936d-69e7610fd2a4.jpg]
[Image: 96891448-93d5-4ec2-8a0e-2ae6062cf5f6.png]
[Image: 792e2d63-ca13-4ffa-9a07-89e69e1092eb.png]
looks like they also have sister boards for Flysky RX and DSM2 Smile
Flysky (FS-I6, Echine I6, TH9X, DEVO 7E with A7105 Module series Transmitter):
http://www.banggood.com/Eachine-FLF3_EVO...91775.html
DSM2
http://www.banggood.com/Eachine-DSF3_EVO...91777.html
  AOS 3" Toothpick build SeismicCWave 24 326 6 hours ago
  Build Meteor75 Build (Revision 4) :) Pathfinder075 9 584 14-Apr-2024, 03:28 AM
  3" 2S 1108 Build Pathfinder075 11 429 14-Apr-2024, 02:08 AM
  Build Armattan Tadpole 3" 2-3S Build brettbrandon 57 3,145 07-Apr-2024, 04:59 PM
  First FPV build. 3.5" help Pums 4 178 04-Apr-2024, 03:23 PM
