15-Feb-2022, 01:26 AM
Nothing big but I want to share this handy cheatsheet with ya' all
LiPo Voltage Quick Chart |
15-Feb-2022, 01:26 AM Nothing big but I want to share this handy cheatsheet with ya' all 15-Feb-2022, 01:56 AM What lipo brands were used for these results? Towards the 0% capacity you still at over 3v? 15-Feb-2022, 12:12 PM These just looks like some generic results. No specific brands have been used. Those charts are just a copy / paste from the following AMPOW article that was created / collated back in 2018 off the back of some data that came from various threads and posts on RC Groups which date back as far as 2005.
19-Feb-2022, 06:22 PM It is generally known that a LiPo battery should not be discharged below 3.5 Volts per cell. Betaflight has an OSD item, "Battery average cell voltage" which displays the per cell volts regardless of the number of cells in the pack. This is likely the single best method to keep track of the battery discharge and current voltage. When it gets down to 3.5v, then one should probably land the craft. The low voltage warning is also set by this value. Additionally, many FC/ESC boards have what is know as a "Low Voltage Cutoff" mechanism that actually cuts the power when the average per cell voltage drops much below 3.5 volts. Both of these work on an average "per cell" value. Consequently, the pilot does not need to calculate nor remember what size pack is being used. Just keep an eye on the per cell voltage. The Betaflight OSD also has "Battery Usage" indicator. Personally, I just use the "Battery Average Cell Voltage" to monitor the battery voltage. For me, it is the easiest method to determine when I should land. 11-May-2022, 12:41 AM Is there any resources on the correlation between discharge rate and effective cycles before battery death? For other Lithium Chemistries, it is possible to get an idea of how many cycles you can get based on depth of discharge, for example, most LiFePO4 batteries can be discharged down to 20% and still get 2000 cycles before you start to lose capacity. Is the rate similar with LiPo? Try Not, Do or Do Not - Yoda |
RX How to show batterie voltage on Turnigy evolution with Fl14+ | Cristof | 2 | 471 | 06-Mar-2023, 03:41 PM Last Post: romangpro | |
No battery voltage in OSD | MindBenderFPV | 4 | 1,321 | 28-Apr-2021, 08:40 PM Last Post: SnowLeopardFPV | |
Tutorial Conditional Voltage alerts with Open TX (1s and 2s) | Diggery | 2 | 2,383 | 21-Jan-2020, 11:54 PM Last Post: SnowLeopardFPV | |
Betaflight no seeing battery voltage | yammahoppy | 12 | 13,674 | 09-Jan-2020, 08:19 PM Last Post: SnowLeopardFPV | |
Tutorial The Perfect Lipo discharge tool? URUAV Lipo Discharger how to Hack DIY | Kerni_fpv | 7 | 9,150 | 16-Dec-2019, 02:19 AM Last Post: sly1935 |
