Can the LED STRIP pad on an F4 FC be reassigned to function as a UART TX? I am trying to wire an R-XSR for f.port and it appears to be the only available pin.
I have a Lumenier Micro Lux V3 stack (link to product info page).
It claims to have 3 UARTs (1, 3, and 6) however only 3 and 6 are labelled on the board. I believe UART 1 is split between SBUS (rx) and LED Strip (tx). UART 3 is smart audio, and UART 6 is camera control.
I'd like to wire UART 1 with f.port, and I'm stumped. I've installed the same hardware on other FC to an actual UART TX pin and it works great, just not this one.
The R-XSR has been flashed with latest ACCESS f.port firmware, and the X-Lite Pro with updated nightly build and they bind just fine.
I am using the uninverted s.port pad on the receiver.
The LED Strip resource was originally assigned to A01, it was unassigned and reassigned with serial TX 1 (since f.port requires the tx pin). Something else was also on A01, I think Sonar something or other. Anything assigned to A01 has been removed and only Serial TX 1 is there now.
SerialRX_halfduplex has been set to both on and off.
serialrx_inverted has been set to both on and off.
serialrx_provider shows correctly as fport.
Am I chasing my tail because this resource cannot be reassigned? If this is the case, I'll disconnect the camera and use UART 6 or just go back to SBUS and smartport (if the LED Strip pad can be used for smartport).
