Posts: 268 Threads: 90 Likes Received: 8 in 8 posts Likes Given: 249 Joined: Jan 2023 Reputation: 0 HEY folks Is the reason for the low of channels to increase latency because they occupy frequencies? Why do many channels reduce latency ? • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,730 Joined: Feb 2019 Reputation: 100 about dji hd transmission or walksail? • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 I don’t understand your question, can you elaborate? Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,730 Joined: Feb 2019 Reputation: 100 dji has 25mbps or 50mps mode. 50mbps does double the data and does need more frequency range, therefor more channels Posts: 268 Threads: 90 Likes Received: 8 in 8 posts Likes Given: 249 Joined: Jan 2023 Reputation: 0 (17-Sep-2023, 09:29 PM)Lemonyleprosy Wrote: I don’t understand your question, can you elaborate? Why does the latency decrease as the channels increase? Meaning: 8 Channels with a latency of less than 16 channels • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,730 Joined: Feb 2019 Reputation: 100 18-Sep-2023, 09:24 AM (This post was last modified: 18-Sep-2023, 09:29 AM by hugnosed_bat.) your question isnt more clear to me. what kind of channels? i dont know any system which does use 16channels for videobtransmission. as told above, channels doesnt matter, they represent a range of frequency. more range of frequency can carry more data the same way, more data can cause more accuracy/a better linkstability or better resolution. channels doesnt anything with the latency, amount of data and how much bandwidth, might be what you are aiming by mention "number of channels" Posts: 268 Threads: 90 Likes Received: 8 in 8 posts Likes Given: 249 Joined: Jan 2023 Reputation: 0 (18-Sep-2023, 09:24 AM)hugnosed_bat Wrote: your question isnt more clear to me. what kind of channels? i dont know any system which does use 16channels for videobtransmission. as told above, channels doesnt matter, they represent a range of frequency. more range of frequency can carry more data the same way, more data can cause more accuracy/a better linkstability or better resolution. channels doesnt anything with the latency, amount of data and how much bandwidth, might be what you are aiming by mention "number of channels" https://oscarliang.com/improve-radio-con...20to%20End • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,730 Joined: Feb 2019 Reputation: 100 18-Sep-2023, 10:26 AM (This post was last modified: 18-Sep-2023, 10:29 AM by hugnosed_bat.) in case of rclink, rc channels. a protocoll with lower channel number does carry less data, can be faster therefor. its not so much about the number of channels its more about the transmission protocoll. i beleieve you are asking for frsky 16channels against 8channels on sbus protocoll? dont be shy, describe your question more. Posts: 1,737 Threads: 60 Likes Received: 1,019 in 735 posts Likes Given: 96 Joined: Jan 2023 Reputation: 52 Maybe you misread the article, the opposite applies. Less channels equals less data equals less latency. Quote:Some common systems have very obvious breakpoints – for example FrSky D16 on 8 channels is twice as fast as D16 using 9-16 channels, for both SBUS and F.Port. Helpfully, there are ways to fit virtually every necessary function into 5-8 channels. • Posts: 268 Threads: 90 Likes Received: 8 in 8 posts Likes Given: 249 Joined: Jan 2023 Reputation: 0 (18-Sep-2023, 10:26 AM)hugnosed_bat Wrote: in case of rclink, rc channels. a protocoll with lower channel number does carry less data, can be faster therefor. its not so much about the number of channels its more about the transmission protocoll. i beleieve you are asking for frsky 16channels against 8channels on sbus protocoll? dont be shy, describe your question more. Do you mean that only the S-BUS system. The fewer channels, the less LETANCY? • |
