Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 Opinions on this charger? Do you know if it has the ability to display internal resistance? https://www.getfpv.com/isdt-d2-smart-bal...gKwNvD_BwE • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 I have the 608 and it does, so I would assume that the D2, considered an upgrade, can as well. OMG, you can shut off the beeper...I want one! SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 (02-Sep-2018, 05:32 PM)kaitylynn Wrote: I have the 608 and it does, so I would assume that the D2, considered an upgrade, can as well. OMG, you can shut off the beeper...I want one! I looked at the manual and it wasn't clear if it displayed the readings or only made a check. My current charger, no pun intended, checks resistance, but doesn't display it. I would like to see the reading for myself. That way I can chart it to keep better tabs on the battery life. So, you're happy with the ISDT brand then? I have had my Hyperion for over 10 years now and it has never missed a beat. Hard to change brands when it has been such a good charger. But technology marches on and the ISDT D2 does so much more.... • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 I am totally happy with ISDT! I have the 608, which is my primary charger and also an old B6 that keeps on charging packs as well. I really like the ISDT better, easier to use with the scroll wheel on the side. Solid construction and flawless performance...the only issue I have with the 608 is the incessant beeping! SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 Another vote for ISDT. I've been very happy with mine. The Q6 Plus shows internal resistance while charging, and it looks like the same firmware as the D2. Posts: 21,243 Threads: 586 Likes Received: 8,959 in 6,630 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 If you're looking at the ISDT D2 you might also want to consider the new kid on the block, which is the Hobbymate D6 Duo that looks very similar to the D2 but has some additional features for just a few dollars more. Most of the big players on YouTube have already reviewed it. Posts: 1,013 Threads: 11 Likes Received: 452 in 349 posts Likes Given: 372 Joined: Dec 2017 Reputation: 16 Love my little ISDT as well. Never has let me down. My only issue with that model is its A/C only. No field charging with it unless you have a generator or portable A/C power pack of some kind. I have a converted PC power supply for A/C charging at home and then take a couple of gel cells into the field to charge if I want. Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 I finally bought a new charger and settled on the Hobbymate D6 that Snow suggested. So far I'm happy with it, but I need to do some mods, i.e. convert the battery connections from XT60s to Deans, and get some balance boards. A little surprised there aren't memory channels. You have to program it for each battery size and type every time you change batteries out. Even my 8 year old Hyperion has memory slots. But other than that it looks like a solid little charger, and very compact. It will be nice to charge/discharge 3 batteries at a time instead of only one. • Posts: 438 Threads: 63 Likes Received: 93 in 70 posts Likes Given: 26 Joined: Jul 2017 Reputation: 1 I just got the Q6 Pro. Love it too |
