14-Jul-2017, 10:09 PM
I'm trying to connect my Inductrix Pro to my Taranis X9D plus and I have all the controls working except throttle, any suggestions?? Please anything ://
Inductrix |
14-Jul-2017, 10:09 PM I'm trying to connect my Inductrix Pro to my Taranis X9D plus and I have all the controls working except throttle, any suggestions?? Please anything :// 16-Jul-2017, 02:26 PM are you using an Orange TX module in your Taranis? As far as I know the Inductrix doesn't support Frsky... Anyway you could try to change channel assignment and swap the controls around, such as this: This video is a bit old but the concept is the same. 16-Jul-2017, 10:11 PM (16-Jul-2017, 02:26 PM)Oscar Wrote: are you using an Orange TX module in your Taranis? As far as I know the Inductrix doesn't support Frsky...Yes I'm using the Orange module, I'll check the video out and see if it helps, thanks 17-Jul-2017, 04:32 AM Did you manage to have a crack at BetaFlight? I hope you get in the air soon... Windless fields and smokeless builds 17-Jul-2017, 04:33 PM 17-Jul-2017, 08:57 PM Are you able to get it connected? When you plug in the inductors and hit connect does it say failed or successful in the top left? 18-Jul-2017, 07:15 AM 20-Jul-2017, 05:25 AM I just had problems with drivers on my new laptop, 24 hours and 8 driver downloads later and finally got BF connected to my Tiny 7 (Also BNF version) {just arrived on Tues, review of which I hope to finish today...} the configuration was 90% complete, but I did need to adjust 'throttle min' setting and confirm 'Arm' and 'Mode' channels... The Impulse RC website has a driver fixer tool which is apparently great, my laptop threw a '.Net Framework' error even after I updated DotNet so it didn't work for me. I can provide links to the 8 things I downloaded for my Win7 Pro (SP1), x64 Lenovo if you like..? TBH I can't say which was the fix that worked, because I'm stupid and forgot to restart the PC till after applying multiple fixes, getting frustrated, sulking, pleading and finally shouting - "Why won't you WORK you useless, piece of !!??" Then my Mrs suggests I "Turn it off, and give the laptop a break for a little while" Oh yeah... "turn it off" Windless fields and smokeless builds 20-Jul-2017, 11:57 PM Like Tom says there's a good chance it's a driver issue. I had them when I started also and it was a huge pain. Make sure you have the right com port and baud rate selected. I thing baud rate is supposed to be 9600 but I could be wrong. Hate to tell you this but if you don't connect to betaflight it's not getting off the ground. |
Help Is anyone still flying the Inductrix Pro? | master468 | 1 | 352 | 03-Feb-2022, 04:04 PM Last Post: Rob3ddd | |
PLEASE HELP: INDUCTRIX | Spiinner | 24 | 12,385 | 26-May-2018, 03:00 AM Last Post: kaitylynn | |
Inductrix FPV Pro Video Channel Confusion | Dronenut | 2 | 2,374 | 11-Feb-2018, 10:37 PM Last Post: Dronenut | |
Inductrix clone build - | kaitylynn | 22 | 3,481 | 09-Jul-2017, 02:54 PM Last Post: kaitylynn | |
Help Blade Inductrix TX bind with another Inductrix | SkinnyShark | 3 | 2,480 | 05-Feb-2017, 03:43 AM Last Post: Jim |
