iNav Cofigurator 6.1.1 not loading
Hello
 I have a Quad with Matek F722std and FW6.1.1 installed and up untill 3 days ago it worked just fine then I made a big Boo Boo - I decided to clean up my DeskTop's filling system - Baaaaaad thing to do
   So now I still have iNav's Confgurator Icon on the  Task Bar - any manner of clicking on it does not load the Configurator but if I hover the curser over it it presents a small picture of the Configurator (what is that1st page called)
To pull back from the Brink I reloaded all Drivers (the ones I know about) CP210x ; STM32102 used ImpulseRC & Zadig - No Joy
 I have a vigin LapTop ....essentially same result after Drivers reinstalled - but  methinks its got summert to do with these Drivers - am missing summert here - would GOOGLE have owt to do with it - am I correct in saying they don't support iNav and other FC's now
So Gentlemen Aviators what to do - please help...joe
After clicking the INAV button on your Task Bar to run INAV, check Task Manager to see if you have at least one process entry listed for "inav-configurator". If you do then the INAV Configurator is likely just running outside of the boundaries of your screen in which case do the following:
  1. Click on the INAV button on your Task Bar
  2. Hold down the <ALT> key while pressing the <SPACEBAR>
  3. A context menu should popup somewhere on the screen with Restore, Move, Size, Minimize, Maximize and Close option on it.
  4. Use the DOWN arrow key on your keyboard to select the "Move" option and press <ENTER>.
  5. Then use your arrow keys to move the window back within the boundaries of your screen and press <ENTER> when it is in the place you want it to be.
If the above doesn't work, just reset all the INAV Configurator settings (which includes the window position) by opening a Windows Command Prompt and then running the following command...
rmdir /s %LOCALAPPDATA%\inav-configurator
  Recently flashed INAV to speedybee f405 and already had issues on quad crash. grozaalex 0 302 03-May-2024, 09:25 PM
Last Post: grozaalex
  Switch from BF 4.5 RC3 to INAV Maverick 0 203 19-Apr-2024, 08:44 AM
Last Post: Maverick
  Announcement INAV 7.1 - Compass No Longer Required SnowLeopardFPV 2 641 15-Apr-2024, 10:34 PM
  inav artificial horizon offset range quinn 5 234 08-Apr-2024, 12:38 AM
Last Post: StuweFPV
  Add a Servo Button in INav techdesk 1 269 14-Mar-2024, 01:38 PM
Last Post: StuweFPV
