INAV 6 + FLYING WING: ENGINE STARTS AND STOPS, STARTS AND STOPS.....
Hello everyone
on an arwing pro with matek 722 flashed in inav6, I am confronted with a new behavior of the engine without being able to determine the cause.
after the first 2 flights where everything is going well, it is now impossible to fly the engine normally, which only starts and stops in manual mode or in launchmode, while being piloted under INAV, by the "manual" interface of inav, the motor responds nominally.
under the inav inreface, one can verify that the receiver also responds normally on all axes.
who would have an idea to submit to deepen the diagnosis and above all find a solution, because he urges me to fly this wing again which positively surprised me during these 2 short first flights
A+
there is not enough information about your setup and behavior to give you a definitive answer.. what has changed in v6 is that there is no longer a "disable extra arming safety" which makes it more complicated now to arm a plane (can be hacked). a diff file would be helpful. but it is strange that it works 2 times and without changing anything it suddenly stops working. but then again i'm not sure if i truly understand your issue. like when you fly and switch into ACRO mode the motor stops???
Video Build Twin engine Turbo Lidl with panning camera L0stB1t 6 1,025 03-May-2024, 04:28 PM
Last Post: L0stB1t
  Help Which wing for SpeedybeeF405 wing Griffin Ucos 4 544 07-Feb-2024, 07:55 AM
Last Post: Green_Weedle
  Best FC for inav or ardupilot? PJKMBAKER 0 502 05-Nov-2023, 12:21 PM
Last Post: PJKMBAKER
  Discussion Fpv wing for beginners pofotiou 4 517 08-Sep-2023, 08:30 PM
Last Post: StuweFPV
  Went flying yesterday with the old wing guys Rob Axel 2 404 14-May-2023, 06:31 PM
