How to mount micro cameras?
All of my frames have mountings for full-size (28mm) FPV cameras. I've got a couple of Foxeer mini-sized (21mm) cams which come with a bracket that bulks them out to 28mm. But the whole industry seems to be moving towards micro cameras to the point that even minis are getting a little bit thin on the ground. Caddx don't even seem to make anything bigger than a micro any more.
So how are people mounting micro cameras? Particularly people with full-size frames?
I mostly see printed mounts anymore. Plug your frame into thingiverse and see what you get.
[-] The following 1 user Likes Sugs's post:
  • Krohsis
Frames are going micro too. I buy the camera for the frame. I really haven't replaced the camera on the older full size frames. I have just used an adapter in the past.
Question Help Betaflight OSD is not working (F405v3, TX800, Foxeer T-Rex Micro) maggrave 5 1,488 20-Oct-2023, 11:17 PM
  Help FCF411-FTE & Video TX Atlatl HV micro problems ashewan 0 258 15-Jan-2023, 02:34 PM
Last Post: ashewan
  Help XILO Micro Mutant lens replacement goldfinv 2 441 27-Sep-2021, 06:44 AM
Last Post: goldfinv
  succex micro f4 2.1 flight controller separate vtx wiring Yodabutt 22 27,088 19-Apr-2021, 05:03 PM
Last Post: voodoo614
  What connectors for cameras?? Rob3ddd 7 1,560 05-Apr-2021, 07:38 AM
Last Post: EdisonBulb
