Apparently I have a newer model with V2 or V3 gimbals. Mine have multiple allen screws in the top of the gimbals. I watched several videos explaining how to remove the rear cover and adjust tension on the plates, but mine look nothing like the plates in the examples. My brand new Transmitter has a throttle stick which will literally droop all the way to the bottom under its own weight if it's left past half-way. I need to increase the tension. There is also no detent (no clicks) when increasing throttle, but that's OK. I just found it unusual because every other radio I've ever purchased has defaulted to a "clicky" throttle gimbal.
I do not have a video of the top of the gimbals, but here's a short video showing the internals (ignore the cat). Can anyone give me some advice on how to properly adjust these gimbals so my throttle stick isn't so loose. I really don't want to return this, as it's probably something simple.
