17-Feb-2022, 07:46 PM
Hello wizards and experts,
I have a problem with a new ESC I have installed on my quad. The ESC is a Holybro Tekko32 F4 Metal 65A... This is replacing a Tekko32 F3 Metal 65A that caught fire one day when plugging in a battery, but I digress.
After the fire that ruined the original Tekko32 ESC, I replaced it with a newer F4 model, soldered the motors and it seemed to be working ok on the bench but one of the motors sounded different than the other three so I decided to replace all 4 motors. So I now have the FC and ESC installed in the drone and the motors are soldered to the ESC. When testing the setup on the bench with the battery plugged in, I spin the motors from ~0-50% throttle for ~10 seconds (with no errors shown) then all motors stop spinning and the voltage indicated in betaflight drops from ~15V to ~7V.
The ESC firmware is 32.8 and I've tried betaflight 4.2.10 and 4.3 (RC3) Firmware for the Kakute F7 FC. The motors are Xing E Pro 2306 2450KV.
I've triple checked the solder pads on the ESC and I haven't bridged any connections that I can see, no solder balls (I mask the circuitry with masking tape before soldering). Maybe I damaged the ESC with too much heat? This is the second set of motors I've soldered to the board...
Any troubleshooting tips?
Thanks in advance!
Thanks in advance!
