Posts: 8 Threads: 2 Likes Received: 6 in 3 posts Likes Given: 0 Joined: Sep 2022 Reputation: 0 Hi! My name is Nikita. I've been more of a spectator than an active FPV pilot and watched a lot of videos by Flite Test, Rotor Riot, Joshua Bardwell, etc. I'm now finishing my first build that uses the Lumenier QAV-R 2 frame and, while everything has gone smooth, I've encountered a problem when doing the final assembly. When I was tightening the screws on the bottom plate I accidentally tightened the screws on the top plate too and noticed that the top clear layer of the carbon frame started to separate from the frame. The same happened on the other side of top plate where it meets with the standoffs and for some motor and arm screws. To avoid doing the same mistake in future I'd like to ask whether you think this is caused by tightening the screws to much and applying high pressure to the frame or there is an issue with my particular frame. I'm a little bit disappointed since I've thought that the frame is the most durable part of the build and haven't expected this to happen. Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 Welcome to intoFPV. Carbon fibre can be brittle and chips/breaks if the screws are over tightened. I am not sure how you were torquing the screws but using a hex bit in a wrench is a no no since you have too much leverage. Simply use a standard size hex key to snug the screws. You can add loctite (blue not red as red requires heat to break the bond) to all the screws on the frame after completing the build (except for the top plate since you may need to take it off for repairs). • Posts: 5,850 Threads: 47 Likes Received: 2,773 in 2,235 posts Likes Given: 7,601 Joined: Jul 2019 Reputation: 97 11-Sep-2022, 02:54 AM (This post was last modified: 11-Sep-2022, 03:12 AM by iFly4rotors.) Hi Grassydragon, First, Welcome Since that is a brand new frame, I would contact the vendor and see if I could get them to replace the "faulty" top plate. After all, it is new and it did "splinter" so maybe you can get a new top plate. If they will not replace that top plate, use it anyway. I will be fine. Any minor damage to the plate in that area will likely not adversely effect anything and will like NOT break further. I would not consider that plate to really be damaged. Although, it may be a quality issue, you run that risk when tightening bolts directly against a material that is multi-layered as is carbon fiber. Yes, you could just not tighten the bolts vey tight, however, it is not purely about the "tightness", but rather the rotary action of the bolt head against the material once the bolt head makes contact, even before it is "tight. This phenomenon is not limited to carbon fiber quad plates; it has the same effect on any material that is soft, "non-durable", or multi-layered. Consequently, I almost always use a flat metal washer on the bolt between the plate and the bolt head. Now, you can tighten away or at least until you can't, something bends, or something breaks (ha, ha...but true none the less). Just by using a metal washer, you will resolve this issue. NOTE: Nylon washers can also be damaged by the turning bolt head. I generally do not use Locktite unless a bolt loosens during test flights. I will check them before each flight. If I notice one or more becoming loose, then I might use some of the blue Locktite. I probably should use it on motor bolts, but I don't. Interestingly, I have never had a bolt come out and only a few times where one or two became loose. Yeah, I probably should use the Locktite, but I generally tighten my bolts enough that they just don't come loose. I tighten them pretty tight and don't use any type of torque wrench or such. I just tighten the bolts pretty tight and the carbon fiber does NOT get damaged regardless of how much I tighten them. I do use metal washers. For FC stacks and such and on some bolts that hold the bottom frame plates together, I will use nyloc nuts. Now, these are NOT generally feasible for the standoff columns. Also, I have been know to use nylon standoff columns to save weight and I do NOT use Locktite on these. Sometimes, I will use an "O" ring and a flat metal washer instead of a locking nyloc nut. The "O" ring provides some tension {like a spring} which prevents the nut from backing off. Now, I don't normally do this for the frame plates, however, I have used this method on FC stacks. Interestingly, I don't think that I have seen any builds {except mine} where metal washers are used; washers are generally not included in frame kits. For some reason {maybe cost?}, the FPV world doesn't seem to use washers. On the other hand, I DO. My knowledge of the use of washers was acquired from a long history of construction and repair of a wide variety of things {from car motors to houses}. When I started building quads, M2 and M3 flat stainless steel washers were some of the first things that I purchased. I use them all the time and my builds always stay together and I have not damaged any of the carbon fiber plates. • Posts: 8 Threads: 2 Likes Received: 6 in 3 posts Likes Given: 0 Joined: Sep 2022 Reputation: 0 Hi kafie1980 and iFly4rotors! Thanks for your wisdom! Quote:I am not sure how you were torquing the screws but using a hex bit in a wrench is a no no since you have too much leverage. I wasn't using a wrench but rather a screwdriver with a hex bit. It had a big handle though so in the end I switched to an L-shaped hex key. I forgot how simple it was to select an appropriate leverage by adjusting the position of my fingers. These keys comes from my RC car there stripping threads in plastic parts is a common issue. Quote:Since that is a brand new frame, I would contact the vendor and see if I could get them to replace the "faulty" top plate. Unfortunately, I purchased the frame two years ago so there is no chance I can replace the top plate. However, I hope that only the top clear layer was damaged and it only provides a smooth finish and not a structural strength. • Posts: 5,850 Threads: 47 Likes Received: 2,773 in 2,235 posts Likes Given: 7,601 Joined: Jul 2019 Reputation: 97 Hi Grassydragon, From the looks of it, I would agree that what actually splintered was a clear coat and not the actual carbon fiber. So, it likely will not effect the structural integrity. In that front location on the top plate, I don't think that you will have any issues with stength. Personally, I would not worry about it especailly at this point. I have repaired broken carbon fiber frames and arms with very good success. What you have is not actually broken. In fact, I bet you could scrape that off and discover that the actual carbon fiber has not been broken or even splintered. Since the cam brace is also wedged between the top and bottom plated that will also serve to hold things in place and add a bit of strength to the structure. I believe that everything will be fine. There is a higher probability that you will break an arm. Let's get this bird completed and in the air. By the way, I would suggest {please do} that you start a BUILD thread in the Mini Quad section so that we might all follow along. That would also be a better place for questions and comments since it would get better exposure and keep everything about that build in one thread. • Posts: 8 Threads: 2 Likes Received: 6 in 3 posts Likes Given: 0 Joined: Sep 2022 Reputation: 0 Hi! I've created a build thread here: https://intofpv.com/t-lumenier-qav-r-2-6 By the way, Alex Vanover now offers a frame that comes with washers (for some reason I can't see them on the website, however, they were presented in his video): https://vannystyle.com/products/vannystyle-frame • Posts: 6,091 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,718 Joined: Feb 2019 Reputation: 100 i never had that on quality carbon, as tight as "possible" by hand, the frame is something we like to be as stiff as possible. i would suggest to skip that frame, maybe for later experiments, not for a beginner build. • Posts: 8 Threads: 2 Likes Received: 6 in 3 posts Likes Given: 0 Joined: Sep 2022 Reputation: 0 Quote:i would suggest to skip that frame, maybe for later experiments, not for a beginner build. Since the quad has already been built and flies well, I'll continue flying it and see whether anything breaks • Posts: 4,731 Threads: 392 Likes Received: 3,231 in 1,827 posts Likes Given: 3,214 Joined: Apr 2019 Reputation: 101 I like Chris Rosser's rule of thumb: use the same number of fingers to torque screws as the metric size ... so use 2 fingers for M2, 3 for M3. For me, it's not so much crushing the CF but stripping the screws. Welcome to the forum! • Posts: 8 Threads: 2 Likes Received: 6 in 3 posts Likes Given: 0 Joined: Sep 2022 Reputation: 0 Quote:I like Chris Rosser's rule of thumb: use the same number of fingers to torque screws as the metric size ... so use 2 fingers for M2, 3 for M3. Sounds interesting! I sometimes hold a screwdriver more loosely so that it starts to slip in my hand when tension increases. • Posts: 6,091 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,718 Joined: Feb 2019 Reputation: 100 20-Sep-2022, 10:55 AM (This post was last modified: 20-Sep-2022, 11:02 AM by hugnosed_bat.) (20-Sep-2022, 01:15 AM)the.ronin Wrote: I like Chris Rosser's rule of thumb: use the same number of fingers to torque screws as the metric size ... so use 2 fingers for M2, 3 for M3. For me, it's not so much crushing the CF but stripping the screws. Welcome to the forum! xD funny rule from chris xD but any hand has different abilities. my two finger torq will be completly different to others... that rule cant be adapted to others. for true precision a "torq meter" is needed, for a particular torqlevel you could use the tool to check your added nm, if you are able to adjust by feel. i guess the general rule is; on quality screws, nuts, standoffs and carbon - its pretty difficult to do something worng. to get good tight fit on a new build, retighten them after maiden flights does help. Posts: 5,850 Threads: 47 Likes Received: 2,773 in 2,235 posts Likes Given: 7,601 Joined: Jul 2019 Reputation: 97 Hi Bat, What torque wrench do you use? Got a Link? I tighten my frame and motor bolts just until they will not turn and the bolt "Feels" REAL tight. When the bolt will no longer turn, I sort of "test the torque" by trying to turn it just a "wee" bit with moderate, but not too much pressure. I do NOT Force it. I use nyloc nuts or "O" ring washers on FC bolts. An "O" ring acts like a spring and applies pressure when compressed preventing the nut from turning. It might sound crazy, but it does work. I have both black steel and stainless steel bolts, nuts, and nyloc nuts. Oddly, there are different sizes of each, however, both types seem to be quality...at least quality enough to NOT easily strip or break. I also use aluminum stand offs most of the time. I will use a bolt that goes down into the column about 5mm so that they have plenty of "grip". If the bolt only goes into the column a mm or 2 then get a longer bolt because a couple of threads will not tighten enough, will strip easily, and generally Do NOT not hold well. {yeah, I generally chuck those short top plate bolts and use longer ones}. So far, I have never stripped a bolt, nut, nor column. A word to the wise: When starting a bolt into the column, motor, or nut; turn slowly, gently, and sort of "vibrate" it a little until the correct alignment is found where the bolt turns easily into the threads. Do NOT force it {it is likely Not lined up straight}. If the bolt does not turn easily then STOP, remove the bolt, and try it again. NEVER force a bolt to start into the threads as you might cross thread it and damage the threads on the nut, the column, or the bolt. Side Note: The only bolts that I have ever used a torque wrench on were Head Bolts on car motors. • Posts: 6,091 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,718 Joined: Feb 2019 Reputation: 100 https://nz.element14.com/duratool/d03003...dp/2581865 this is what i found so far. personal i feel comfortable without any tool. • Posts: 5,850 Threads: 47 Likes Received: 2,773 in 2,235 posts Likes Given: 7,601 Joined: Jul 2019 Reputation: 97 (20-Sep-2022, 01:55 PM)hugnosed_bat Wrote: https://nz.element14.com/duratool/d03003...dp/2581865 this is what i found so far. personal i feel comfortable without any tool. Hi Bat, Thanks for the link. I have never seen one of those. I couldn't find it on the US website, but will look other places. The other thing is the price at over $ 150.00 USD. WOW. Posts: 6,091 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,718 Joined: Feb 2019 Reputation: 100 i didnt watch the price xD a proud price for tightening screws xD • |
