Threads: 1
Likes Received: 0 in 0 posts
0 24-May-2018, 12:38 AM (This post was last modified: 24-May-2018, 12:39 AM by funnyandwise.) Hi, my drone's VTX is an Eachine VTX03, and I also have an RC832 Reciever. I have Quanum v2 DIY goggles, and everything is wired correctly (camera and VTX are directly soldered to PDB- camera and vtx both on 5 volts). When I turn everything on, the goggles just display static and say "NO SIGNAL." I've been through all 40 channels/frequencies on both the vtx and rx, but there is no video. However, every time I do something like changing the VTX's channel, the static in the goggles changes, and occasionally there is a black screen. I've been working on this for a few months now, please help!!!
Threads: 129
Likes Received: 2,740 in 1,644 posts
Likes Given: 2,969
65 Power level is not reading "O"? I have not had too many issues with the VTX-03's. KT-Bug and The Japalura both have them and they work well. I power the camera from the FC and not through the VTX on The Bug. I kept having an issue like you describe when I tried to power it through the VTX. What camera are you using, BTW?
SoCal Kaity :D
OMG, no one told me it would be this much fun! Addicted :)
Threads: 136
Likes Received: 1,790 in 1,052 posts
Likes Given: 3,302
50 As Kaity said, double check that the vtx isn't set to zero output power.
Also check the actual V being supplied to the cam and vtx. Personally I have always used 12v (or 9V more recently) to power the vtx.
Threads: 13
Likes Received: 25 in 23 posts
Likes Given: 33
0 1 thing I have seen on generic can it only used 12v so as They have said check v out put. Make sure your mated correctly on antennas some have pin some dont.... I know these are basics but I have missed them myself
