31-Mar-2024, 12:28 AM
Hey there. I'm new here and new also with FPV drone (DIY). I have been piloting dji mini2, mini3 pro and avata. As I have the DJI ecosystem, probably I started incorrectly.
I started ordering the DJI O3 Air unit to use with my existing goggles and control, and I tried to find a FC and ESC for that. I did a lot of research and decided order a Mamba F722 AP with a ESC 50A.
I tried to use a custom frame (Avata like project), but the FC space was tight and I needed a smaller FC. I ordered a Mamba F722 Mini 40A ESC (unique model). I could fit the FC and the DJI O3, but the weight with battery is getting 300 to 350g (due to the main frame and avata frames). I have plans to use my 4S battery, and the motors I have handy - 1404 xing motors 4600KV 4S (with 16.25A peak - just learned later).
concern: this motor has peak 16.25A and my Mamba ESC stack is 40A.
I know that Mamba are not cheap ones but I tried the easiest interface and compatibility and use my DJI ecosystem (maybe the first mistake).
I contacted Mamba support asking about their recommendation for motors and max weight, the tech guys are really bad and they just answered that I can't have a drone bigger than 250g (as I told, my drone is around 350g).
I really would like to use the following, at least:
- Mamba F722 Mini + ESC 40A (20mm x 20mm)
- DJI O3 Air unit (vtx, receiver) with 25,5 x 25,5mm
I just ordered an OddityRC XI25 frame (fits FC with 20x20mm and also O3), but looks the internal height looks not to fit all in the center and I'm thinking about use a small extensor to allow that.
I have others items handy:
- iflight Xing 1404 4600kv
- Propellers D63 x 3
- Lipo 4S - with 100g (preferred)
- Lipo 6S - with 200g
I'm really lost if I can try this new frame and customize it, but my question now is on the motors. Which would be the maxium peak allowed for a ESC 40A (45A burst 10s), considering 4 motors.
Tks so much!
My main Now I have a Mini FC (20mmx20mm), really hard to find frames with this
Tks so much!
