Goggle Antennas and what to buy ?
[Moderator Edit] This is a clone of an old thread on reddit HERE. This user account is for a known spammer who included spam links in the post, so those have been removed and the user account has been banned. The thread will remain [undeleted] because other members have already added contributions that might still be useful to others.
So am planning to buy my first set of goggles and i wan't them to last, which is why am going for theFatshark HDO and the ImmersionRC rapidFIRE reciever.
However i don't know which antenna to pick, what i mean by that is :That i don't know if the reciever antennas are universal or drone/ build specific ?Can i use the same antena for the mobula7 or do i need another antena if i switch drone, If so how do i know which to pick for my goggles?
Additional question do i need a reciever module when i train in the simulator
For your goggles just get a omni and a patch for 5.8GHz and they are RHCP polarized. (this is pretty much standard for analog quads).
If you have an OpenTX radio, you can play sim connected via USB joystick mode.
You can use the same antennae for all of your quads. Antennae are specific to a frequency and very little else, so as long as your quads are on 5.8GHz (and if they're on analog video they will be) and you're using the same polarisation on the quad and the goggles then you're golden.
You might also consider using 2 omni antennae for Rapidfire. Some people reckon it works just as well because of the frame recombination magic.
Lumenier makes. 188mm sma right angle AXII 2 antenna. Gets it up above your head. $20.00 us
For the other I put a large patch on a 45 sma connector..
Hi! For every day I use set Foxeer Pagoda omni plus Maple double patch
Or two Foxeer Pagoda for short flights (up to 700m) around
[Image: ant-2021-09-28.jpg]
Also in my practice good Foxeer Lolipop 3 for quad and for goggle.
I recommend using a long ~15cm antenna so that there is less radio shadow from the head.
  Discussion What radio/controller would you buy if you had $350 to spend ??? BigBeard 28 1,215 14-Sep-2022, 09:14 AM
  Goggle Antennas and what to buy ? driplpent 8 920 21-Jan-2022, 11:02 PM
Last Post: ArkansasFPV
  Goggle Antennas and what to buy ? hasinvadi48 2 348 19-Dec-2020, 11:08 AM
  Did I buy/build a clone? Deal-E-O 3 852 29-Nov-2019, 09:20 PM
Last Post: Deal-E-O
  Help Help on first mini quad build - what to buy? joserendon5102 20 4,032 25-Feb-2016, 10:01 AM
Last Post: lolFPV
