Threads: 11
Likes Received: 28 in 23 posts
Likes Given: 101
1 I clipped the tip off of one of the two diversity ELRS antennas on my 6" freestyle rig. It happens to be off the Mateksys R24-D, which is shipped with antennas that have a chunky thing at the end of the antenna. Hard to find replacements for those if I want the exact one. Can I just use one of my old FrSky 2.4gHz antennas I have laying around? It doesn't have the awkward chunky thing on the end and the length of the exposed wire is different.
Also, how important is it for the 2 diversity antennas to match?
Threads: 117
Likes Received: 811 in 658 posts
Likes Given: 126
20 30-May-2023, 12:54 AM (This post was last modified: 30-May-2023, 12:56 AM by Rob Axel.) When I was replacing the rxsr / xm+ antennas they came in different length exposed elements. I was also playing with a Emax d-8 rx.. I read research on %s, wave lengths ect.. and got lots of “opinions”.
PropsOFF FPV suggested I tried 32.8mm(if I remember correctly)..stated .”guys flying “other lengths” were dropping out, and we (32.8mm) were still going”…
Not sure if it was just a Frsky d8 thing or if it was a 2.4ghz thing.. but I have a ELRS antenna needing replacement .. I’m starting at 32.8 mm. (If that is the length )
And YES! My d8 rx out flew the 400mw vtx In clear line of site..
Threads: 11
Likes Given: 101
1 Awesome data! Thanks!
Looks like the best antennas have to be ordered from Poland??
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 The prodrone.pl antennas are excellent, but the takeaway should be that almost all of the tested antennas are plenty good enough.
