Binding FrSKY R-XSR to Jumper T18 Lite ISSUE
Please can someone Help!!
I am fairly new to FPV..
I have:
-the iFlight Green Hornet cinewhoop
- FrSky R-XSR receiver
- Jumper T18 Lite radio
When following FrSky/youtube video instructions on binding (holding down F/S button when powering on), my R-XSR doesn't do the right flashing LED Lights - all it does is have constant Red,Green,Blue LEDs, nothing changes if i try binding etc.
Then when I turn on normally it there is still the blue LED with flashing red LED.
What is going on?
Am I already bound without realising (please god)
Do I need to flash the receiver again?!
Flash the radio?
Any help would be great, I can post some pics if possible.
Many thanks!
Did the R-XSR come pre-installed or did you install it yourself?
Either way, it may have firmware on the R-XSR isn't compatible with the mode you are selecting on your T18. Have you flashed any new firmware to the R-XSR? If yes then which type and version?
And what version of the multiprotocol firmware is installed on your Jumper T18 Lite?
  betaflight config 10.10 RC2 issue Rob Axel 3 233 10-Feb-2024, 01:21 PM
  random uncommanded yaw issue in flight? husafreak 30 979 16-Jan-2024, 05:32 AM
Last Post: husafreak
  FrSky replacement antenna suitable for 2.4gHz ELRS replacement? EyeBotXander 4 631 31-May-2023, 08:05 AM
Last Post: V-22
  TBS CROSSFIRE TX LITE is stuck in binding mode Seanalami 3 786 26-Mar-2022, 12:56 PM
Last Post: Seanalami
  FRsky r-xsr F-Port can't communicate with Mamba f722 Trackzero 3 670 07-Sep-2021, 11:15 AM
