Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 Foxeer CineWhoop 25, HDZero, PNP, fitted Happymodel ELRS. I have contacted Foxeer, this to try a second option to get what I need. Delivered new to me 10th March, NO info contained, NO info on box, NO support Link to files, NO QCode, nothing looking at their website directly, NIX, NADA................. Usual 3 Profiles, Profile 1 being quite a way from the default BF settings so assume this their custom set up, the other two are default. Rest set up just like all my other quads, but its wholly unstable, out of trim, and super erratically nervous despite rates of 600ish. Their website seems to lack all normal support info. Obviously I immediately took a stored copy of dump, etc on arrival, but it certainly does not want to fly it! I noted that "their" profile is being warned on the BF PID page as likely to cause runaways, etc. Hardly encouraging! Anyone have a known working dump and diff all from their one please I can compare/correct ? • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,731 Joined: Feb 2019 Reputation: 100 12-Mar-2023, 10:03 PM (This post was last modified: 12-Mar-2023, 10:05 PM by hugnosed_bat.) i have no dump sry. a costum tune sgould be something nice, specialy on a "cinewhoop" which require adjustements. pretty bad it doesnt work as it should the warning of betaflight doesnt count anything, a "cinewhoop" does require very high d-values, betaflight does warn as it would cause a flyaway on a quad with high power to weight ratio. its absolutly normal to tune a whoop like that in that d-value area. dont mention that warning, it realy doesnt tell anyithing 8n the case of your build, the warning is more a sign its tuned in the right direction than something is wrong. there is no risk for a runaway on that build, the warning doesnt match. Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 Cine Whoops are new to me, no experience! The motors sound abnormal, even for a ducted, they sound exactly like gritty bearings, with a vibration that can be felt in the frame, cannot be helping. (They spin smoothly by hand, no noises, no play). They are also getting a bit warmer than I'm used to even in the short time (seconds) that its flown, when near everything I have with that treatment stays cool Sound like a filter issue? Dump as supplied............. # dump # version # Betaflight / STM32F745 (S745) 4.3.1 Jul 13 2022 / 03:35:21 (8d4f005) MSP API: 1.44 # config: manufacturer_id: FOXE, board_name: FOXEERF745V3_AIO, version: 24268d36, date: 2022-09-13T04:39:05Z # start the command batch batch start board_name FOXEERF745V3_AIO manufacturer_id FOXE # name: FoxWhoop WaF # resources resource BEEPER 1 D02 resource MOTOR 1 B04 resource MOTOR 2 B05 resource MOTOR 3 B01 resource MOTOR 4 B00 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 NONE resource PWM 1 NONE resource PWM 2 NONE resource PWM 3 NONE resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource SONAR_TRIGGER 1 NONE resource SONAR_ECHO 1 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 B10 resource SERIAL_TX 4 A00 resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 E08 resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 B11 resource SERIAL_RX 4 A01 resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 E07 resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource I2C_SCL 1 B08 resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SCL 4 NONE resource I2C_SDA 1 B09 resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource I2C_SDA 4 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 NONE resource TRANSPONDER 1 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 C10 resource SPI_SCK 4 E02 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 C11 resource SPI_MISO 4 E05 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 C12 resource SPI_MOSI 4 E06 resource CAMERA_CONTROL 1 B03 resource ADC_BATT 1 C03 resource ADC_RSSI 1 C05 resource ADC_CURR 1 C02 resource ADC_EXT 1 C01 resource BARO_CS 1 NONE resource BARO_EOC 1 NONE resource BARO_XCLR 1 NONE resource COMPASS_CS 1 NONE resource COMPASS_EXTI 1 NONE resource SDCARD_CS 1 NONE resource SDCARD_DETECT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource USB_MSC_PIN 1 NONE resource FLASH_CS 1 E04 resource OSD_CS 1 A04 resource RX_SPI_CS 1 NONE resource RX_SPI_EXTI 1 NONE resource RX_SPI_BIND 1 NONE resource RX_SPI_LED 1 NONE resource RX_SPI_CC2500_TX_EN 1 NONE resource RX_SPI_CC2500_LNA_EN 1 NONE resource RX_SPI_CC2500_ANT_SEL 1 NONE resource RX_SPI_EXPRESSLRS_RESET 1 NONE resource RX_SPI_EXPRESSLRS_BUSY 1 NONE resource GYRO_EXTI 1 D00 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A15 resource GYRO_CS 2 NONE resource USB_DETECT 1 NONE resource VTX_POWER 1 NONE resource VTX_CS 1 NONE resource VTX_DATA 1 NONE resource VTX_CLK 1 NONE resource PULLUP 1 NONE resource PULLUP 2 NONE resource PULLUP 3 NONE resource PULLUP 4 NONE resource PULLDOWN 1 NONE resource PULLDOWN 2 NONE resource PULLDOWN 3 NONE resource PULLDOWN 4 NONE # timer timer A08 AF1 # pin A08: TIM1 CH1 (AF1) timer B03 AF1 # pin B03: TIM2 CH2 (AF1) timer B00 AF2 # pin B00: TIM3 CH3 (AF2) timer B01 AF2 # pin B01: TIM3 CH4 (AF2) timer B04 AF2 # pin B04: TIM3 CH1 (AF2) timer B05 AF2 # pin B05: TIM3 CH2 (AF2) # dma dma SPI_MOSI 1 NONE dma SPI_MOSI 2 NONE dma SPI_MOSI 3 NONE dma SPI_MOSI 4 NONE dma SPI_MISO 1 NONE dma SPI_MISO 2 NONE dma SPI_MISO 3 NONE dma SPI_MISO 4 NONE dma SPI_TX 1 NONE dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_TX 4 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma SPI_RX 4 NONE dma ADC 1 0 # ADC 1: DMA2 Stream 0 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin A08 0 # pin A08: DMA2 Stream 6 Channel 0 dma pin B03 0 # pin B03: DMA1 Stream 6 Channel 3 dma pin B00 0 # pin B00: DMA1 Stream 7 Channel 5 dma pin B01 0 # pin B01: DMA1 Stream 2 Channel 5 dma pin B04 0 # pin B04: DMA1 Stream 4 Channel 5 dma pin B05 0 # pin B05: DMA1 Stream 5 Channel 5 # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature RX_SERIAL feature TELEMETRY feature OSD feature ANTI_GRAVITY # serial serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 1 1 115200 57600 0 115200 serial 2 0 115200 57600 0 115200 serial 3 64 115200 57600 0 115200 serial 6 0 115200 57600 0 115200 # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mixer smix reset # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon RX_LOST beacon RX_SET # map map AETR1234 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1300 1700 0 0 aux 1 0 0 900 900 0 0 aux 2 0 0 900 900 0 0 aux 3 0 0 900 900 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 0 0 0 0 0 0 0 0 vtxtable band 2 BOSCAM_B B FACTORY 0 0 0 0 0 0 0 0 vtxtable band 3 BOSCAM_E E FACTORY 0 0 0 0 0 0 0 0 vtxtable band 4 FATSHARK F FACTORY 0 5760 0 5800 0 0 0 0 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 IMD6 I FACTORY 0 0 0 0 0 0 0 0 vtxtable powerlevels 3 vtxtable powervalues 14 23 0 vtxtable powerlabels 25 200 0 # vtx vtx 0 0 0 0 0 900 900 vtx 1 0 0 0 0 900 900 vtx 2 0 0 0 0 900 900 vtx 3 0 0 0 0 900 900 vtx 4 0 0 0 0 900 900 vtx 5 0 0 0 0 900 900 vtx 6 0 0 0 0 900 900 vtx 7 0 0 0 0 900 900 vtx 8 0 0 0 0 900 900 vtx 9 0 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set gyro_hardware_lpf = OPTION_2 set gyro_lpf1_type = PT1 set gyro_lpf1_static_hz = 0 set gyro_lpf2_type = PT1 set gyro_lpf2_static_hz = 500 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = AUTO set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_count = 1 set dyn_notch_q = 500 set dyn_notch_min_hz = 150 set dyn_notch_max_hz = 600 set gyro_lpf1_dyn_min_hz = 0 set gyro_lpf1_dyn_max_hz = 500 set gyro_lpf1_dyn_expo = 5 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -33,0,24,1 set align_mag = CW180 set mag_align_roll = 0 set mag_align_pitch = 0 set mag_align_yaw = 1800 set mag_bustype = I2C set mag_i2c_device = 1 set mag_i2c_address = 0 set mag_spi_device = 0 set mag_hardware = NONE set mag_calibration = 0,0,0 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = NONE set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set mid_rc = 1500 set min_check = 1050 set max_check = 2000 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rssi_src_frame_lpf_period = 30 set rc_smoothing = ON set rc_smoothing_auto_factor = 45 set rc_smoothing_auto_factor_throttle = 30 set rc_smoothing_setpoint_cutoff = 0 set rc_smoothing_feedforward_cutoff = 0 set rc_smoothing_throttle_cutoff = 0 set rc_smoothing_debug_axis = ROLL set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = SBUS set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set srxl2_unit_id = 1 set srxl2_baud_fast = ON set sbus_baud_fast = OFF set crsf_use_rx_snr = OFF set crsf_use_negotiated_baud = OFF set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set msp_override_channels_mask = 0 set rx_spi_protocol = V202_250K set rx_spi_bus = 0 set rx_spi_led_inversion = OFF set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_sample_rate = 1/1 set blackbox_device = SPIFLASH set blackbox_disable_pids = OFF set blackbox_disable_rc = OFF set blackbox_disable_setpoint = OFF set blackbox_disable_bat = OFF set blackbox_disable_mag = OFF set blackbox_disable_alt = OFF set blackbox_disable_rssi = OFF set blackbox_disable_gyro = OFF set blackbox_disable_acc = OFF set blackbox_disable_debug = OFF set blackbox_disable_motors = OFF set blackbox_disable_gps = OFF set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 600 set dshot_burst = OFF set dshot_bidir = ON set dshot_bitbang = AUTO set dshot_bitbang_timer = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT300 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 12 set motor_output_reordering = 0,1,2,3,4,5,6,7 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 15 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set failsafe_recovery_delay = 10 set failsafe_stick_threshold = 30 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 45 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 430 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 330 set vbat_warning_cell_voltage = 350 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_display_lpf_period = 30 set vbat_sag_lpf_period = 2 set ibat_lpf_period = 10 set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 100 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set mixer_type = LEGACY set crashflip_motor_percent = 0 set crashflip_expo = 35 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 180 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = NONE set gps_sbas_integrity = OFF set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_ublox_mode = AIRBORNE set gps_set_home_point_once = OFF set gps_use_3d_speed = OFF set gps_rescue_angle = 32 set gps_rescue_alt_buffer = 15 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_landing_alt = 5 set gps_rescue_landing_dist = 10 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1100 set gps_rescue_throttle_max = 1600 set gps_rescue_ascend_rate = 500 set gps_rescue_descend_rate = 150 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set gps_rescue_allow_arming_without_fix = OFF set gps_rescue_alt_mode = MAX_ALT set gps_rescue_use_mag = ON set deadband = 2 set yaw_deadband = 3 set yaw_control_reversed = OFF set pid_process_denom = 2 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set simplified_gyro_filter = ON set simplified_gyro_filter_multiplier = 100 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = METRIC set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = ON set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set telemetry_disabled_cap_used = ON set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set ledstrip_brightness = 100 set sdcard_detect_inverted = OFF set sdcard_mode = OFF set sdcard_spi_bus = 0 set sdio_clk_bypass = OFF set sdio_use_cache = OFF set sdio_use_4bit_width = OFF set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = ON set osd_warn_rc_smoothing = ON set osd_warn_fail_safe = ON set osd_warn_launch_control = ON set osd_warn_no_gps_rescue = ON set osd_warn_gps_rescue_disabled = ON set osd_warn_rssi = OFF set osd_warn_link_quality = OFF set osd_warn_rssi_dbm = OFF set osd_warn_over_cap = OFF set osd_rssi_alarm = 20 set osd_link_quality_alarm = 80 set osd_rssi_dbm_alarm = -60 set osd_cap_alarm = 650 set osd_alt_alarm = 100 set osd_distance_alarm = 0 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_logo_on_arming = OFF set osd_logo_on_arming_duration = 5 set osd_tim1 = 1280 set osd_tim2 = 769 set osd_vbat_pos = 2497 set osd_rssi_pos = 376 set osd_link_quality_pos = 2487 set osd_link_tx_power_pos = 234 set osd_rssi_dbm_pos = 2455 set osd_tim_1_pos = 439 set osd_tim_2_pos = 2519 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 53 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 78 set osd_display_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 14794 set osd_avg_cell_voltage_pos = 2465 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 235 set osd_nheading_pos = 234 set osd_up_down_reference_pos = 205 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_esc_rpm_freq_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 234 set osd_pid_profile_name_pos = 234 set osd_profile_name_pos = 234 set osd_rcchannels_pos = 234 set osd_camera_frame_pos = 35 set osd_efficiency_pos = 234 set osd_total_flights_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set osd_stat_min_link_quality = OFF set osd_stat_flight_dist = OFF set osd_stat_max_fft = OFF set osd_stat_total_flights = OFF set osd_stat_total_time = OFF set osd_stat_total_dist = OFF set osd_stat_min_rssi_dbm = OFF set osd_profile = 1 set osd_profile_1_name = - set osd_profile_2_name = - set osd_profile_3_name = - set osd_gps_sats_show_hdop = OFF set osd_displayport_device = MSP set osd_rcchannels = -1,-1,-1,-1 set osd_camera_frame_width = 24 set osd_camera_frame_height = 11 set osd_stat_avg_cell_value = OFF set osd_framerate_hz = 12 set osd_menu_background = TRANSPARENT set task_statistics = ON set debug_mode = GYRO_SCALED set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set enable_stick_arming = OFF set vtx_band = 5 set vtx_channel = 1 set vtx_power = 0 set vtx_low_power_disarm = OFF set vtx_softserial_alt = OFF set vtx_freq = 5658 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vtx_spi_bus = 0 set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = NOMINAL set max7456_spi_bus = 1 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_msp_serial = 1 set displayport_msp_attrs = 0,0,0,0 set displayport_msp_use_device_blink = OFF set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set frsky_spi_autobind = OFF set frsky_spi_tx_id = 0,0,0 set frsky_spi_offset = 0 set frsky_spi_bind_hop_data = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 set frsky_x_rx_num = 0 set frsky_spi_a1_source = VBAT set cc2500_spi_chip_detect = ON set led_inversion = 0 set dashboard_i2c_bus = 0 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_button_resistance = 450,270,150,68,0 set camera_control_inverted = OFF set rangefinder_hardware = NONE set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = ON set flash_spi_bus = 4 set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 3 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW90 set gyro_1_align_roll = 0 set gyro_1_align_pitch = 0 set gyro_1_align_yaw = 900 set gyro_2_bustype = SPI set gyro_2_spibus = 0 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = CW0 set gyro_2_align_roll = 0 set gyro_2_align_pitch = 0 set gyro_2_align_yaw = 0 set i2c1_pullup = OFF set i2c1_clockspeed_khz = 800 set i2c2_pullup = OFF set i2c2_clockspeed_khz = 800 set i2c3_pullup = OFF set i2c3_clockspeed_khz = 800 set i2c4_pullup = OFF set i2c4_clockspeed_khz = 800 set mco2_on_pc9 = OFF set spektrum_spi_protocol = 0 set spektrum_spi_mfg_id = 0,0,0,0 set spektrum_spi_num_channels = 0 set expresslrs_uid = 0,0,0,0,0,0 set expresslrs_domain = AU433 set expresslrs_rate_index = 0 set expresslrs_switch_mode = HYBRID set expresslrs_model_id = 255 set scheduler_relax_rx = 25 set scheduler_relax_osd = 25 set timezone_offset_minutes = 0 set rpm_filter_harmonics = 3 set rpm_filter_q = 500 set rpm_filter_min_hz = 100 set rpm_filter_fade_range_hz = 50 set rpm_filter_lpf_hz = 150 set flysky_spi_tx_id = 0 set flysky_spi_rf_channels = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 set stats_min_armed_time_s = -1 set stats_total_flights = 0 set stats_total_time_s = 0 set stats_total_dist_m = 0 set name = FoxWhoop WaF set display_name = - set position_alt_source = DEFAULT set position_alt_gps_min_sats = 10 set position_alt_baro_fallback_sats = 7 set box_user_1_name = - set box_user_2_name = - set box_user_3_name = - set box_user_4_name = - profile 0 # profile 0 set profile_name = - set dterm_lpf1_dyn_min_hz = 120 set dterm_lpf1_dyn_max_hz = 240 set dterm_lpf1_dyn_expo = 5 set dterm_lpf1_type = PT1 set dterm_lpf1_static_hz = 120 set dterm_lpf2_type = PT1 set dterm_lpf2_static_hz = 240 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_sag_compensation = 0 set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5800 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = OFF set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 15 set iterm_windup = 85 set iterm_limit = 400 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 250 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 108 set i_pitch = 250 set d_pitch = 99 set f_pitch = 209 set p_roll = 74 set i_roll = 198 set d_roll = 87 set f_roll = 143 set p_yaw = 74 set i_yaw = 198 set d_yaw = 0 set f_yaw = 143 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 87 set d_min_pitch = 99 set d_min_yaw = 0 set d_max_gain = 37 set d_max_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 0 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 set thrust_linear = 0 set transient_throttle_limit = 0 set feedforward_transition = 0 set feedforward_averaging = 2_POINT set feedforward_smooth_factor = 65 set feedforward_jitter_factor = 7 set feedforward_boost = 15 set feedforward_max_rate_limit = 90 set dyn_idle_min_rpm = 45 set dyn_idle_p_gain = 50 set dyn_idle_i_gain = 50 set dyn_idle_d_gain = 50 set dyn_idle_max_increase = 150 set level_race_mode = OFF set simplified_pids_mode = RPY set simplified_master_multiplier = 150 set simplified_i_gain = 150 set simplified_d_gain = 195 set simplified_pi_gain = 110 set simplified_dmax_gain = 0 set simplified_feedforward_gain = 80 set simplified_pitch_d_gain = 100 set simplified_pitch_pi_gain = 140 set simplified_dterm_filter = ON set simplified_dterm_filter_multiplier = 160 rateprofile 0 # rateprofile 0 set rateprofile_name = - set thr_mid = 50 set thr_expo = 0 set rates_type = BETAFLIGHT set quickrates_rc_expo = OFF set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 15 set pitch_expo = 15 set yaw_expo = 10 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set tpa_rate = 65 set tpa_breakpoint = 1750 set tpa_mode = D set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 set roll_level_expo = 0 set pitch_level_expo = 0 # end the command batch batch end # diff all # version # Betaflight / STM32F745 (S745) 4.3.1 Jul 13 2022 / 03:35:21 (8d4f005) MSP API: 1.44 # config: manufacturer_id: FOXE, board_name: FOXEERF745V3_AIO, version: 24268d36, date: 2022-09-13T04:39:05Z # start the command batch batch start # reset configuration to default settings defaults nosave board_name FOXEERF745V3_AIO manufacturer_id FOXE mcu_id 002400425030501620323530 signature # name: FoxWhoop WaF # feature feature -RX_PARALLEL_PWM feature -AIRMODE # serial serial 0 0 115200 57600 0 115200 serial 1 1 115200 57600 0 115200 serial 3 64 115200 57600 0 115200 # beacon beacon RX_LOST beacon RX_SET # aux aux 0 0 0 1300 1700 0 0 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 0 0 0 0 0 0 0 0 vtxtable band 2 BOSCAM_B B FACTORY 0 0 0 0 0 0 0 0 vtxtable band 3 BOSCAM_E E FACTORY 0 0 0 0 0 0 0 0 vtxtable band 4 FATSHARK F FACTORY 0 5760 0 5800 0 0 0 0 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 IMD6 I FACTORY 0 0 0 0 0 0 0 0 vtxtable powerlevels 3 vtxtable powervalues 14 23 0 vtxtable powerlabels 25 200 0 # master set gyro_hardware_lpf = OPTION_2 set gyro_lpf1_static_hz = 0 set dyn_notch_count = 1 set dyn_notch_q = 500 set gyro_lpf1_dyn_min_hz = 0 set acc_calibration = -33,0,24,1 set mag_hardware = NONE set baro_hardware = NONE set max_check = 2000 set rc_smoothing_auto_factor = 45 set blackbox_sample_rate = 1/1 set dshot_idle_value = 600 set dshot_bidir = ON set motor_pwm_protocol = DSHOT300 set motor_poles = 12 set align_board_yaw = 45 set small_angle = 180 set deadband = 2 set yaw_deadband = 3 set pid_process_denom = 2 set report_cell_voltage = ON set osd_cap_alarm = 650 set osd_tim1 = 1280 set osd_tim2 = 769 set osd_vbat_pos = 2497 set osd_rssi_pos = 376 set osd_link_quality_pos = 2487 set osd_rssi_dbm_pos = 2455 set osd_tim_1_pos = 439 set osd_tim_2_pos = 2519 set osd_vtx_channel_pos = 53 set osd_craft_name_pos = 78 set osd_warnings_pos = 14794 set osd_avg_cell_voltage_pos = 2465 set osd_disarmed_pos = 235 set osd_displayport_device = MSP set debug_mode = GYRO_SCALED set vtx_band = 5 set vtx_channel = 1 set vtx_freq = 5658 set displayport_msp_serial = 1 set gyro_1_align_yaw = 900 set name = FoxWhoop WaF profile 0 # profile 0 set dterm_lpf1_dyn_min_hz = 120 set dterm_lpf1_dyn_max_hz = 240 set dterm_lpf1_static_hz = 120 set dterm_lpf2_static_hz = 240 set anti_gravity_gain = 5800 set yaw_lowpass_hz = 250 set p_pitch = 108 set i_pitch = 250 set d_pitch = 99 set f_pitch = 209 set p_roll = 74 set i_roll = 198 set d_roll = 87 set f_roll = 143 set p_yaw = 74 set i_yaw = 198 set f_yaw = 143 set d_min_roll = 87 set d_min_pitch = 99 set feedforward_averaging = 2_POINT set feedforward_smooth_factor = 65 set dyn_idle_min_rpm = 45 set simplified_master_multiplier = 150 set simplified_i_gain = 150 set simplified_d_gain = 195 set simplified_pi_gain = 110 set simplified_dmax_gain = 0 set simplified_feedforward_gain = 80 set simplified_pitch_pi_gain = 140 set simplified_dterm_filter_multiplier = 160 profile 1 profile 2 # restore original profile selection profile 0 rateprofile 0 # rateprofile 0 set rates_type = BETAFLIGHT set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 15 set pitch_expo = 15 set yaw_expo = 10 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set tpa_breakpoint = 1750 rateprofile 1 rateprofile 2 rateprofile 3 rateprofile 4 rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save # status MCU F745 Clock=216MHz, Vref=3.27V, Core temp=30degC Stack size: 2048, Stack address: 0x20010000 Configuration: CONFIGURED, size: 4128, max available: 32768 Devices detected: SPI:1, I2C:0 Gyros detected: gyro 1 locked dma GYRO=ICM42688P, ACC=ICM42688P OSD: MSP System Uptime: 176 seconds, Current Time: 2023-03-10T13:06:10.179+00:00 CPU:24%, cycle time: 126, GYRO rate: 7936, RX rate: 15, System rate: 9 Voltage: 3 * 0.01V (0S battery - NOT PRESENT) I2C Errors: 0 SD card: Not configured Arming disable flags: RXLOSS CLI MSP RPMFILTER # • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,731 Joined: Feb 2019 Reputation: 100 12-Mar-2023, 11:07 PM (This post was last modified: 12-Mar-2023, 11:10 PM by hugnosed_bat.) as it is a brand new pnp, it should work without issue. maybe some sound post? a video? a strange motorsound can also sign an issue with the esc some heat on the motors shouldnt get you nervous, high d-values big motors for the rotorsize, mass on rpms does give some heat, more one "cinewhoops" if you does a punchout and dont get pain by hold the motors, you should be fine. while foxeer is a realy reputable player about cams, their escs looks decent to me either... but maybe you got a bad product maybe more information about tje issue would help to figure out the source. edit: that values looks truly strange coatumized high pids :-@ hopefully somone can provide a dump what happens on defaults on profile one? • Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 All I have done is fitted an ELRS Rx to the end of wiring from the buried inside frame FC board, wiring they provide. In Setup the quad image moves as expected, accelerometers can be calibrated. Have now deliberately calibrated "off" then back again, that works. In Betaflight, Rx settings are 1000-2000 and mid 1500, stable, and on screen quad is not drifting and responds to Tx stick moves correctly. When armed all motors idle but have an abnormal "vibration" noise which can be felt in the frame when held, but they spin freely by hand when battery disconnected and apart from expected magnetic cogging they are smooth, no mechanical issue. I told Foxeer of noise, and that the model was totally unstable as soon as in air, and asked for a support "Dump" file and ESC settings, and got this reply.................. Hi Sir You can just bind the Rx and fly, nothing elses need to config, the BF default setting is good enough, no need to make anothe customized version Oh Dear......................... Juggling Phone and Tx...............this is video of noise. The initial changes to pitch/speed are not due MY control changes, its just sat at idle after arming. • Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,731 Joined: Feb 2019 Reputation: 100 13-Mar-2023, 12:07 PM (This post was last modified: 13-Mar-2023, 12:09 PM by hugnosed_bat.) that sounds pretty impressive like a faulty esc. how does it sound in the motortab? i would ask for a replacement. i would take their words: "it should work without any settup" - it sounds like a dying or faulty esc or wrong settings, it needs to be replaced. the costumer service might not be knowledgeable, it might be a test for their reputation. maybe you should also share the link for their costumer service, they get known its an issue above their knowledge... and the community will judge theirbreputation from an issue like this. they should just send you a working one, it would be simple, hopefully you will get in the air with a working one soon • Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 (13-Mar-2023, 12:07 PM)hugnosed_bat Wrote: that sounds pretty impressive like a faulty esc. how does it sound in the motortab? Individually and as a set the motors run cleanly in Betaflight Motors tab, no undue noise, no undue warming up, and whatever they are set to, they maintain evenly, no fluctuation. • Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 As a point, this model comes from Foxeer set up with BlueJay, of which I have NO experience. • Posts: 137 Threads: 2 Likes Received: 59 in 50 posts Likes Given: 207 Joined: Mar 2022 Reputation: 2 Here is the dump from mine: # dump # version # Betaflight / STM32F745 (S745) 4.3.0 Apr 25 2022 / 01:05:26 (9d71184) MSP API: 1.44 # config: manufacturer_id: FOXE, board_name: FOXEERF745V2_AIO, version: c84fcf9f, date: 2022-05-07T08:37:04Z # start the command batch batch start board_name FOXEERF745V2_AIO manufacturer_id FOXE # name: - # resources resource BEEPER 1 D02 resource MOTOR 1 B04 resource MOTOR 2 B05 resource MOTOR 3 B01 resource MOTOR 4 B00 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 NONE resource PWM 1 NONE resource PWM 2 NONE resource PWM 3 NONE resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource SONAR_TRIGGER 1 NONE resource SONAR_ECHO 1 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 B10 resource SERIAL_TX 4 A00 resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 E08 resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 B11 resource SERIAL_RX 4 A01 resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 E07 resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource I2C_SCL 1 B08 resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SCL 4 NONE resource I2C_SDA 1 B09 resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource I2C_SDA 4 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 NONE resource TRANSPONDER 1 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 C10 resource SPI_SCK 4 E02 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 C11 resource SPI_MISO 4 E05 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 C12 resource SPI_MOSI 4 E06 resource CAMERA_CONTROL 1 B03 resource ADC_BATT 1 C03 resource ADC_RSSI 1 C05 resource ADC_CURR 1 C02 resource ADC_EXT 1 C01 resource BARO_CS 1 NONE resource BARO_EOC 1 NONE resource BARO_XCLR 1 NONE resource COMPASS_CS 1 NONE resource COMPASS_EXTI 1 NONE resource SDCARD_CS 1 NONE resource SDCARD_DETECT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource USB_MSC_PIN 1 NONE resource FLASH_CS 1 E04 resource OSD_CS 1 A04 resource RX_SPI_CS 1 NONE resource RX_SPI_EXTI 1 NONE resource RX_SPI_BIND 1 NONE resource RX_SPI_LED 1 NONE resource RX_SPI_CC2500_TX_EN 1 NONE resource RX_SPI_CC2500_LNA_EN 1 NONE resource RX_SPI_CC2500_ANT_SEL 1 NONE resource RX_SPI_EXPRESSLRS_RESET 1 NONE resource RX_SPI_EXPRESSLRS_BUSY 1 NONE resource GYRO_EXTI 1 D00 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A15 resource GYRO_CS 2 NONE resource USB_DETECT 1 NONE resource VTX_POWER 1 NONE resource VTX_CS 1 NONE resource VTX_DATA 1 NONE resource VTX_CLK 1 NONE resource PULLUP 1 NONE resource PULLUP 2 NONE resource PULLUP 3 NONE resource PULLUP 4 NONE resource PULLDOWN 1 NONE resource PULLDOWN 2 NONE resource PULLDOWN 3 NONE resource PULLDOWN 4 NONE # timer timer A08 AF1 # pin A08: TIM1 CH1 (AF1) timer B03 AF1 # pin B03: TIM2 CH2 (AF1) timer B00 AF2 # pin B00: TIM3 CH3 (AF2) timer B01 AF2 # pin B01: TIM3 CH4 (AF2) timer B04 AF2 # pin B04: TIM3 CH1 (AF2) timer B05 AF2 # pin B05: TIM3 CH2 (AF2) # dma dma SPI_MOSI 1 NONE dma SPI_MOSI 2 NONE dma SPI_MOSI 3 NONE dma SPI_MOSI 4 NONE dma SPI_MISO 1 NONE dma SPI_MISO 2 NONE dma SPI_MISO 3 NONE dma SPI_MISO 4 NONE dma SPI_TX 1 NONE dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_TX 4 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma SPI_RX 4 NONE dma ADC 1 0 # ADC 1: DMA2 Stream 0 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin A08 0 # pin A08: DMA2 Stream 6 Channel 0 dma pin B03 0 # pin B03: DMA1 Stream 6 Channel 3 dma pin B00 0 # pin B00: DMA1 Stream 7 Channel 5 dma pin B01 0 # pin B01: DMA1 Stream 2 Channel 5 dma pin B04 0 # pin B04: DMA1 Stream 4 Channel 5 dma pin B05 0 # pin B05: DMA1 Stream 5 Channel 5 # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature RX_SERIAL feature TELEMETRY feature OSD feature ANTI_GRAVITY # serial serial 20 1 115200 57600 0 115200 serial 0 64 115200 57600 0 115200 serial 1 1 115200 57600 0 115200 serial 2 0 115200 57600 0 115200 serial 3 0 115200 57600 0 115200 serial 6 0 115200 57600 0 115200 # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mixer smix reset # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon -RX_LOST beacon -RX_SET # map map AETR1234 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1700 2100 0 0 aux 1 1 1 900 1300 0 0 aux 2 2 1 1300 1700 0 0 aux 3 13 255 1700 2100 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 0 0 0 0 0 0 0 0 vtxtable band 2 BOSCAM_B B FACTORY 0 0 0 0 0 0 0 0 vtxtable band 3 BOSCAM_E E FACTORY 0 0 0 0 0 0 0 0 vtxtable band 4 FATSHARK F FACTORY 0 5760 0 5800 0 0 0 0 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 IMD6 I FACTORY 0 0 0 0 0 0 0 0 vtxtable powerlevels 3 vtxtable powervalues 14 23 0 vtxtable powerlabels 25 200 0 # vtx vtx 0 0 0 0 0 900 900 vtx 1 0 0 0 0 900 900 vtx 2 0 0 0 0 900 900 vtx 3 0 0 0 0 900 900 vtx 4 0 0 0 0 900 900 vtx 5 0 0 0 0 900 900 vtx 6 0 0 0 0 900 900 vtx 7 0 0 0 0 900 900 vtx 8 0 0 0 0 900 900 vtx 9 0 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set gyro_hardware_lpf = NORMAL set gyro_lpf1_type = PT1 set gyro_lpf1_static_hz = 375 set gyro_lpf2_type = PT1 set gyro_lpf2_static_hz = 750 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = AUTO set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_count = 2 set dyn_notch_q = 300 set dyn_notch_min_hz = 100 set dyn_notch_max_hz = 1000 set gyro_lpf1_dyn_min_hz = 375 set gyro_lpf1_dyn_max_hz = 750 set gyro_lpf1_dyn_expo = 5 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -58,-24,57,1 set align_mag = CW180 set mag_align_roll = 0 set mag_align_pitch = 0 set mag_align_yaw = 1800 set mag_bustype = I2C set mag_i2c_device = 1 set mag_i2c_address = 0 set mag_spi_device = 0 set mag_hardware = NONE set mag_calibration = 0,0,0 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = NONE set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rssi_src_frame_lpf_period = 30 set rc_smoothing = ON set rc_smoothing_auto_factor = 30 set rc_smoothing_auto_factor_throttle = 30 set rc_smoothing_setpoint_cutoff = 0 set rc_smoothing_feedforward_cutoff = 0 set rc_smoothing_throttle_cutoff = 0 set rc_smoothing_debug_axis = ROLL set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = CRSF set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set srxl2_unit_id = 1 set srxl2_baud_fast = ON set sbus_baud_fast = OFF set crsf_use_rx_snr = OFF set crsf_use_negotiated_baud = OFF set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set msp_override_channels_mask = 0 set rx_spi_protocol = V202_250K set rx_spi_bus = 0 set rx_spi_led_inversion = OFF set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_sample_rate = 1/4 set blackbox_device = SPIFLASH set blackbox_disable_pids = OFF set blackbox_disable_rc = OFF set blackbox_disable_setpoint = OFF set blackbox_disable_bat = OFF set blackbox_disable_mag = OFF set blackbox_disable_alt = OFF set blackbox_disable_rssi = OFF set blackbox_disable_gyro = OFF set blackbox_disable_acc = OFF set blackbox_disable_debug = OFF set blackbox_disable_motors = OFF set blackbox_disable_gps = OFF set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 550 set dshot_burst = OFF set dshot_bidir = ON set dshot_bitbang = AUTO set dshot_bitbang_timer = AUTO set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 12 set motor_output_reordering = 0,1,2,3,4,5,6,7 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 15 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set failsafe_recovery_delay = 10 set failsafe_stick_threshold = 30 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 45 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 430 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 330 set vbat_warning_cell_voltage = 350 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_display_lpf_period = 30 set vbat_sag_lpf_period = 2 set ibat_lpf_period = 10 set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 100 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set mixer_type = LEGACY set crashflip_motor_percent = 0 set crashflip_expo = 35 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 25 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = NONE set gps_sbas_integrity = OFF set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_ublox_mode = AIRBORNE set gps_set_home_point_once = OFF set gps_use_3d_speed = OFF set gps_rescue_angle = 32 set gps_rescue_alt_buffer = 15 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_landing_alt = 5 set gps_rescue_landing_dist = 10 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1100 set gps_rescue_throttle_max = 1600 set gps_rescue_ascend_rate = 500 set gps_rescue_descend_rate = 150 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set gps_rescue_allow_arming_without_fix = OFF set gps_rescue_alt_mode = MAX_ALT set gps_rescue_use_mag = ON set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set simplified_gyro_filter = ON set simplified_gyro_filter_multiplier = 150 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = METRIC set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set telemetry_disabled_cap_used = ON set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set ledstrip_brightness = 100 set sdcard_detect_inverted = OFF set sdcard_mode = OFF set sdcard_spi_bus = 0 set sdio_clk_bypass = OFF set sdio_use_cache = OFF set sdio_use_4bit_width = OFF set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = ON set osd_warn_rc_smoothing = ON set osd_warn_fail_safe = ON set osd_warn_launch_control = ON set osd_warn_no_gps_rescue = ON set osd_warn_gps_rescue_disabled = ON set osd_warn_rssi = OFF set osd_warn_link_quality = OFF set osd_warn_rssi_dbm = OFF set osd_warn_over_cap = OFF set osd_rssi_alarm = 20 set osd_link_quality_alarm = 80 set osd_rssi_dbm_alarm = -60 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_distance_alarm = 0 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_logo_on_arming = OFF set osd_logo_on_arming_duration = 5 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2497 set osd_rssi_pos = 234 set osd_link_quality_pos = 2081 set osd_link_tx_power_pos = 234 set osd_rssi_dbm_pos = 234 set osd_tim_1_pos = 234 set osd_tim_2_pos = 2518 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 2104 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 2508 set osd_vtx_channel_pos = 234 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 234 set osd_display_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 14665 set osd_avg_cell_voltage_pos = 2465 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_up_down_reference_pos = 205 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_esc_rpm_freq_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 234 set osd_pid_profile_name_pos = 234 set osd_profile_name_pos = 234 set osd_rcchannels_pos = 234 set osd_camera_frame_pos = 35 set osd_efficiency_pos = 234 set osd_total_flights_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set osd_stat_min_link_quality = OFF set osd_stat_flight_dist = OFF set osd_stat_max_fft = OFF set osd_stat_total_flights = OFF set osd_stat_total_time = OFF set osd_stat_total_dist = OFF set osd_stat_min_rssi_dbm = OFF set osd_profile = 1 set osd_profile_1_name = - set osd_profile_2_name = - set osd_profile_3_name = - set osd_gps_sats_show_hdop = OFF set osd_displayport_device = MSP set osd_rcchannels = -1,-1,-1,-1 set osd_camera_frame_width = 24 set osd_camera_frame_height = 11 set osd_stat_avg_cell_value = OFF set osd_framerate_hz = 12 set osd_menu_background = TRANSPARENT set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set enable_stick_arming = OFF set vtx_band = 5 set vtx_channel = 1 set vtx_power = 0 set vtx_low_power_disarm = OFF set vtx_softserial_alt = OFF set vtx_freq = 5658 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vtx_spi_bus = 0 set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = NOMINAL set max7456_spi_bus = 1 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_msp_serial = 1 set displayport_msp_attrs = 0,0,0,0 set displayport_msp_use_device_blink = OFF set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set frsky_spi_autobind = OFF set frsky_spi_tx_id = 0,0,0 set frsky_spi_offset = 0 set frsky_spi_bind_hop_data = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 set frsky_x_rx_num = 0 set frsky_spi_a1_source = VBAT set cc2500_spi_chip_detect = ON set led_inversion = 0 set dashboard_i2c_bus = 0 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_button_resistance = 450,270,150,68,0 set camera_control_inverted = OFF set rangefinder_hardware = NONE set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = ON set flash_spi_bus = 4 set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 3 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW0 set gyro_1_align_roll = 0 set gyro_1_align_pitch = 0 set gyro_1_align_yaw = 0 set gyro_2_bustype = SPI set gyro_2_spibus = 0 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = CW0 set gyro_2_align_roll = 0 set gyro_2_align_pitch = 0 set gyro_2_align_yaw = 0 set i2c1_pullup = OFF set i2c1_clockspeed_khz = 800 set i2c2_pullup = OFF set i2c2_clockspeed_khz = 800 set i2c3_pullup = OFF set i2c3_clockspeed_khz = 800 set i2c4_pullup = OFF set i2c4_clockspeed_khz = 800 set mco2_on_pc9 = OFF set spektrum_spi_protocol = 0 set spektrum_spi_mfg_id = 0,0,0,0 set spektrum_spi_num_channels = 0 set expresslrs_uid = 0,0,0,0,0,0 set expresslrs_domain = AU433 set expresslrs_rate_index = 0 set expresslrs_switch_mode = HYBRID set expresslrs_model_id = 255 set scheduler_relax_rx = 25 set scheduler_relax_osd = 25 set timezone_offset_minutes = 0 set rpm_filter_harmonics = 2 set rpm_filter_q = 500 set rpm_filter_min_hz = 100 set rpm_filter_fade_range_hz = 50 set rpm_filter_lpf_hz = 150 set flysky_spi_tx_id = 0 set flysky_spi_rf_channels = 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 set stats_min_armed_time_s = -1 set stats_total_flights = 0 set stats_total_time_s = 0 set stats_total_dist_m = 0 set name = - set display_name = - set position_alt_source = DEFAULT set position_alt_gps_min_sats = 10 set position_alt_baro_fallback_sats = 7 set box_user_1_name = - set box_user_2_name = - set box_user_3_name = - set box_user_4_name = - profile 0 # profile 0 set profile_name = - set dterm_lpf1_dyn_min_hz = 75 set dterm_lpf1_dyn_max_hz = 150 set dterm_lpf1_dyn_expo = 5 set dterm_lpf1_type = PT1 set dterm_lpf1_static_hz = 75 set dterm_lpf2_type = PT1 set dterm_lpf2_static_hz = 150 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_sag_compensation = 100 set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 10000 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = OFF set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 10 set iterm_windup = 85 set iterm_limit = 400 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 100 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 75 set i_pitch = 134 set d_pitch = 76 set f_pitch = 199 set p_roll = 71 set i_roll = 127 set d_roll = 67 set f_roll = 191 set p_yaw = 71 set i_yaw = 127 set d_yaw = 0 set f_yaw = 191 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 67 set d_min_pitch = 76 set d_min_yaw = 0 set d_max_gain = 37 set d_max_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 0 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 set thrust_linear = 0 set transient_throttle_limit = 0 set feedforward_transition = 0 set feedforward_averaging = OFF set feedforward_smooth_factor = 25 set feedforward_jitter_factor = 7 set feedforward_boost = 15 set feedforward_max_rate_limit = 90 set dyn_idle_min_rpm = 35 set dyn_idle_p_gain = 50 set dyn_idle_i_gain = 50 set dyn_idle_d_gain = 50 set dyn_idle_max_increase = 150 set level_race_mode = OFF set simplified_pids_mode = RPY set simplified_master_multiplier = 160 set simplified_i_gain = 100 set simplified_d_gain = 140 set simplified_pi_gain = 100 set simplified_dmax_gain = 0 set simplified_feedforward_gain = 100 set simplified_pitch_d_gain = 100 set simplified_pitch_pi_gain = 100 set simplified_dterm_filter = ON set simplified_dterm_filter_multiplier = 100 rateprofile 0 # rateprofile 0 set rateprofile_name = - set thr_mid = 50 set thr_expo = 0 set rates_type = ACTUAL set quickrates_rc_expo = OFF set roll_rc_rate = 7 set pitch_rc_rate = 7 set yaw_rc_rate = 7 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 67 set pitch_srate = 67 set yaw_srate = 67 set tpa_rate = 65 set tpa_breakpoint = 1350 set tpa_mode = D set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 set roll_level_expo = 0 set pitch_level_expo = 0 # end the command batch batch end # diff # version # Betaflight / STM32F745 (S745) 4.3.0 Apr 25 2022 / 01:05:26 (9d71184) MSP API: 1.44 # config: manufacturer_id: FOXE, board_name: FOXEERF745V2_AIO, version: c84fcf9f, date: 2022-05-07T08:37:04Z # start the command batch batch start board_name FOXEERF745V2_AIO manufacturer_id FOXE # feature feature -AIRMODE # serial serial 1 1 115200 57600 0 115200 # aux aux 0 0 0 1700 2100 0 0 aux 1 1 1 900 1300 0 0 aux 2 2 1 1300 1700 0 0 aux 3 13 255 1700 2100 0 0 # vtxtable vtxtable bands 6 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 0 0 0 0 0 0 0 0 vtxtable band 2 BOSCAM_B B FACTORY 0 0 0 0 0 0 0 0 vtxtable band 3 BOSCAM_E E FACTORY 0 0 0 0 0 0 0 0 vtxtable band 4 FATSHARK F FACTORY 0 5760 0 5800 0 0 0 0 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable band 6 IMD6 I FACTORY 0 0 0 0 0 0 0 0 vtxtable powerlevels 3 vtxtable powervalues 14 23 0 vtxtable powerlabels 25 200 0 # master set gyro_lpf1_static_hz = 375 set gyro_lpf2_static_hz = 750 set dyn_notch_count = 2 set dyn_notch_min_hz = 100 set dyn_notch_max_hz = 1000 set gyro_lpf1_dyn_min_hz = 375 set gyro_lpf1_dyn_max_hz = 750 set acc_calibration = -58,-24,57,1 set mag_hardware = NONE set baro_hardware = NONE set serialrx_provider = CRSF set dshot_bidir = ON set motor_poles = 12 set align_board_yaw = 45 set simplified_gyro_filter_multiplier = 150 set osd_vbat_pos = 2497 set osd_link_quality_pos = 2081 set osd_tim_2_pos = 2518 set osd_flymode_pos = 2104 set osd_throttle_pos = 2508 set osd_avg_cell_voltage_pos = 2465 set osd_displayport_device = MSP set vtx_band = 5 set vtx_channel = 1 set vtx_freq = 5658 set displayport_msp_serial = 1 set gyro_1_align_yaw = 0 set rpm_filter_harmonics = 2 profile 0 # profile 0 set vbat_sag_compensation = 100 set anti_gravity_gain = 10000 set iterm_relax_cutoff = 10 set p_pitch = 75 set i_pitch = 134 set d_pitch = 76 set f_pitch = 199 set p_roll = 71 set i_roll = 127 set d_roll = 67 set f_roll = 191 set p_yaw = 71 set i_yaw = 127 set f_yaw = 191 set d_min_roll = 67 set d_min_pitch = 76 set dyn_idle_min_rpm = 35 set simplified_master_multiplier = 160 set simplified_d_gain = 140 set simplified_dmax_gain = 0 rateprofile 0 # end the command batch batch end Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,731 Joined: Feb 2019 Reputation: 100 that looks very different in the pids tab Posts: 137 Threads: 2 Likes Received: 59 in 50 posts Likes Given: 207 Joined: Mar 2022 Reputation: 2 Yes it does! I was actually thinking about trying BF4.4 on this one, because it only flies OK and not great. I still need to research presets that might work before I commit to that. Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 14-Mar-2023, 07:00 AM (This post was last modified: 14-Mar-2023, 07:25 AM by BadRaven.) C2v2, Thanks a lot for posting Dump, I'm about to start to compare line for line, but we will be comparing apples from differing trees, as the the box label on mine and the dump states its a:- Reaper F745 AIO V3 As per your dump, yours is a V2. Just to confirm, this was the as supplied set, or after some action by you? If its as supplied, there should be no major differences??!!!!!! • Posts: 137 Threads: 2 Likes Received: 59 in 50 posts Likes Given: 207 Joined: Mar 2022 Reputation: 2 This is as it came from Foxeer about 6 months ago. Gal shows his PIDs in the video review that he does, but he also has the same V2 board. Posts: 935 Threads: 69 Likes Received: 339 in 253 posts Likes Given: 155 Joined: Dec 2021 Reputation: 19 15-Mar-2023, 05:22 PM (This post was last modified: 15-Mar-2023, 05:25 PM by BadRaven.) OK.............. IT WORKS!!!!!!!! Along the way in fault finding it went unresponsive to Betaflight, no FC action blue LED. I had to dismantle it to get at the button to force it into DFU, nothing else worked. That was a pain in itself due the split carbon top frame and plastic duct bottom frame I then flashed it 4.4 and then back to 4.3.2 as supplied, allowing custom defaults and checking in Betaflight CLI to ensure loaded file appeared to be correct. Then the hassle of finding the right ports, etc (thanks to Gal's video) And it flies (indoors) with no abnormal noise or reaction. On default PIDS/RATES. Weather here now unsuitable for outdoor test or further tune. BUT IT FLIES !! Foxeer really have done themselves and their customers no favours by not having obvious things like files for Dump, ESC settings, Port and Camera settings available anywhere. Without c2v2's dump and the video link to Gal's excellent review, I'd have REALLY been struggling and doubt that I'd have cracked it. I have asked TWICE for copy of files as installed on it for sale, and not been provided. The good news is that they were very quick in responding during their "daytime" work hours, probably the best of all I have experienced. The bad news being I'm pretty sure that they are list reading and have little understanding of the product. After three Emails it should have been escalated to someone there with understanding of the product. The final question left sticking in my throat is:- It came to me in a sealed box with unbroken holographic stickers. It had Profile settings that seemed to be ridiculously high, for example of just one, an i_pitch of 250. However, the second profile was BF default and that flew it no better. So what actually was the fault? Corrupted firmware?? EDIT: Found a gap in the rain (or a lower level of it and have flown it around the patio. STILL so far so good!!! Posts: 6,105 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,731 Joined: Feb 2019 Reputation: 100 15-Mar-2023, 05:29 PM (This post was last modified: 15-Mar-2023, 05:29 PM by hugnosed_bat.) corrupted fimware or other strange settings doesnt chame with the pidprofile we didnt find • |
