Threads: 47
Likes Received: 2,777 in 2,239 posts
Likes Given: 7,617
97 I have a Flywoo GOKU TX-NANO VTX and I am unable to set the power above 25mW.
I have followed the directions for manual changing:
Long Press button for 6S until flashing,
Then short press the button 3 times,
Then wait.
The power LED still only flashes 1 time on each cycle and shows 25 in the OSD.
When I use smart audio from the transmitter/OSD,
I change the power setting to 200,
Set,
Save and exit,
The power setting remains on 25mW.
What am I missing here??? HELP
I have attempted to contact Flywoo support, but the email does not go through.
Threads: 582
Likes Received: 8,929 in 6,605 posts
Likes Given: 1,425
786 06-Nov-2020, 06:08 PM (This post was last modified: 06-Nov-2020, 06:09 PM by SnowLeopardFPV.) First of all, take SmartAudio out of the equation by temporarily disabling it in the Ports tab and then try again.
I haven't looked at the documentation for that VTX but does it come "locked" by default? Some VTX's do so to comply with the local laws in some countries that prohibit a power setting to be used that is above 25mW. In order use higher power you have to "unlock" the receiver which is usually done with a sequence of button presses. If this is the case then it should say so in the manual.
Threads: 47
Likes Given: 7,617
97 I believe that I have resolved this issue.
Interestingly, I couldn't find anything through Google internet searches.
So, I just started tinkering, experimenting, changing things just to see the results.
Even though the manual shows that the Port UART6 Peripherals should be set to (VTX IRC Tramp),
I changed it to (VTX TBS SmartAudio), now it appears to work.
Since I do not yet have anything to actually measure the power output of the VTX, I am relying on the OSD which now changes when you change the setting.
Threads: 125
Likes Given: 99
388 Interesting. This would not be the first time.
