Threads: 2
Likes Received: 0 in 0 posts
0 I'm looking for someone that can help with a technical question on a Kombini FC. I'm putting together my first build and cannot seem to get the video working. I have posted in another thread FC section, in a Flite Test forumn, and even sent my question to Furious FPV and cannot seem to get an answer for any of these locations. Does anyone know where I can go to get a question answered about how the camera is suppose to hook up to the Kombini?
Thanks
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 13-Dec-2016, 07:45 PM (This post was last modified: 13-Dec-2016, 07:46 PM by oyvinla.) The camera signal and ground should be connected to the osd video in or directly to the vtx. The power to the camera can maybe be picked up from the vtx? It all depends on what camera and vtx you got
Do you have a minimosd? The small board on the left on the picture?
Threads: 672
Likes Given: 2,031
139 The connection between Kombini and CTX is only the power, there is no signal connection so as long as you can verify the kombini is giving out the correct power then it's fine.
Check if the VTX is powered on? Do you only get static noise or do you get black screen at a particular channel? The problem could be the VTX or Camera
