FETtec Tiny Leds Wiring
hello so i got the new fettec tiny leds and i wonder what awg wire should i use with this ? and how should i wire it besides 5v and gnd? i see on the stick its also has a 01 02 solder pads ?
Here is the wiring diagram from Fettec:
https://fettec.net/media/pdf/31/8a/28/LED-Stick.pdf
I don't use LEDs, so someone can correct me if I'm wrong. But I would hook up 5v and ground, and your flight controller's LED_STRIP pad to Data In. Then if you want to connect multiple together I would connect Data OUT of one, to Data IN on the other.
[-] The following 1 user Likes MrSolo's post:
  • oysteinllunde
(25-Aug-2021, 11:44 PM)MrSolo Wrote: Here is the wiring diagram from Fettec:
its that simple! thank you :Smile without a diagram its pretty hard to know..
  Mamba F722 Mini - FC leds meaning and beeps phelipems 0 107 11-Apr-2024, 09:26 PM
Last Post: phelipems
Exclamation HGLRC M100-5883 Wiring Fault Coleon 6 393 22-Feb-2024, 10:03 PM
Exclamation Noob Wiring Omen???? Coleon 4 200 10-Feb-2024, 01:44 AM
  Looks like i have some issues on the tiny whoop motor Rosssiiii 24 1,530 02-Feb-2024, 02:20 AM
Last Post: [email protected]
  rush tank 2 ultimate wiring help to argus f7 pro Dice 1 182 21-Jan-2024, 12:09 AM
Last Post: matt0725
