Threads: 583
Likes Received: 8,942 in 6,617 posts
Likes Given: 1,425
786 That's unfortunate. We see quite a few QC issues with BetaFPV gear. It's definitely a brand to stay away from IMO unless you like to roll the dice.
Threads: 117
Likes Received: 811 in 658 posts
Likes Given: 126
20 07-Sep-2021, 10:44 PM (This post was last modified: 07-Sep-2021, 10:49 PM by Rob Axel.) I can say the Darwin in my Tinyhawk Freakstyle is still going… it has taken several “not so nice” crashes.. one bad enough to brake the frame in pieces …and loose a motor..
Threads: 30
Likes Received: 41 in 35 posts
Likes Given: 97
1 I hear you! first EP2 i borked my fault, 2nd rx the ufl connector came off removing the antenna to put on heat shrink, 2nd EP2 had a bridge between the rx and tx pads i couldn't see it but the multimeter could i ran the iron between the pads and managed to clear the bridge, I never could see it. then i found out the hx115 i brought had a defective ESC from the factory so im gonna have to do it again, in the mean time i have soldered 2 quads with tbs hardware without fault.
I'm going on holiday soon so i need to start thinking about what works and what i need to take with me, and i seems elrs is not gonna be on the list for now, it's gonna be a crossfire fest which makes me feel a warm sense of comfort :-) lmao
Youtube A Mistake is only a Mistake if you refuse to correct your error.
Threads: 583
Likes Given: 1,425
786 Wow. That is truly shocking workmanship. BetaFPV QC at it's finest. I've never owned a BetaFPV product but this is probably a prime example of why so many people likely have issues with their products.
