Threads: 13
Likes Received: 4 in 4 posts
Likes Given: 13
1 Just bought tinyhawk 2 Race and the range I get before losing signal is around 100 feet before it failsafes. Pretty sure it’s video going out first but not sure. Anyone else have this quad and what kind of range or you getting? It’s too quick to have such a low range and I am looking for ways to increase it.
Threads: 117
Likes Received: 809 in 657 posts
Likes Given: 126
20 27-Sep-2021, 09:10 PM (This post was last modified: 27-Sep-2021, 09:11 PM by Rob Axel.) I don’t have a TH2 race, but I am familiar with timyhawks..
100 feet before failsafe is “no bueno”.. I know the RXs on these boards are Not the greatest.(spi d-8) but 100 feet is BS..
First make sure your antenna isn’t damaged, you should have approx 32.8mm of exposed element showing (rx antenna not vtx).. if it’s good check the connection on the fc.. make sure nothing got stuck in it.
Do you see rx loss in the goggles or does it just drop out of the sky?..
If video is cutting out . Ur vtx needs to be higher than 25mw
Threads: 117
Likes Given: 126
20 28-Sep-2021, 12:55 AM (This post was last modified: 28-Sep-2021, 01:24 AM by Rob Axel.) Yeah.. if your having the same issue… with multiple quads.. what is the common denominator.. your googles
But your saying it’s “failsafing”… I’m a little lost
Threads: 172
Likes Given: 4,718
100 show us a video of the behavior pls
there would be many reviews you can watch the range of these "quads" reveivers.
mount your rx antennas vertical to get better signal.
Threads: 117
Likes Given: 126
20 I can’t speak for the built in spi d-8 rx… but I do know from experience 32.8mm of exposed element makes a significant difference… that with the Emax d-8 rx I would easily fly my tinyhawk 1,600 feet .. I would loose video and not be able to continue..
I have noticed my Betafpv controller doesn’t have the range /power that my taranis has when flying my d8 rx quads.. but it does well with my UZ65.. I have flow that 900 feet with it..and the antenna is stock..
It’s REALY hard to say.. weak k ow what the specs on our components.. what they are SUPPOSED to do.. but QC is out the window..
Sooo “you never know what your gonna get.”
-Forest Gump-
Threads: 117
Likes Given: 126
20 Yes, what you see in the goggles is only “info”.. when BF 4.?.? Came out and the end user had to load in the vtx tables and power setting… I noticed you can set these to pretty much anything.. just because the goggles SAYS 600.. it doesn’t mean it is..
It uses “steps” and you assign a “power #” to that step.. also if the vtx isn’t unlocked.. it will show the step but the vtx power needed to “physically” be unlocked to be “active” during the “step”…
-clear as mud-??
Threads: 13
Likes Given: 13
1 Today I decided to test the range of the VTX WITHOUT the antennas attached to the TBS Fusion Module. To my surprise the range was the same or BETTER than WITH the antennas! How does this make any sense?
Threads: 38
Likes Given: 430
118 Are you using antennas with SMA connectors? The kind with the center pin? Can you show a photo of the connector?
Also does the SMA connector feel loose?
With the wrong antenna connector it will make a huge difference like day and night the minute you get even a few meters away from yourself especially if you are running just 25mW.
