TinyHawk 3 rtf kit - Radiomaster tx16s mk2
Dear reader,
I have a Emax TinyHawk 3 RTF kit and it works fine.
The range of the controller/drone is atleast aproximity of 200 meter.
I bought a new Radiomaster tx16s mk2 max controller and the droneshop.nl has connect the drone and the controller to each other. Set the switches and general set up.
When iam flying and the drone is 6 or 7 meters away from the tx16s controller, i hear often: LOST TELEMENTRY and the drone fall out of the sky.
No lights or anything. When i walk to the drone it pops on, Lights and message : Telementry connected and the drone wil work again.
It looks that the Rx signal is too low? The orginal Emax E8 controller works fine.
Does anyone know what the problem is !?
VTX is at 25 mw, but it is only the googgels i think !?
--> Please let me know <--
THANKS IN ADVANCE
Hayke ( (NLD)
What do u see in the googles when it falls (rx loss)? And it only does it with the radio master?
But You say “no lights”.. does the quad shut off COMPLETELY?? If this is the case.. it’s ur connection to the lipo…those connections arnt the greatest.. try bending the pins SHIGHTLY to get a good contact. Also check the plug to see if the pins are moving out of the back of the plug
  A 4" build that never flew (The Ronin mk2 is alive!) drumgod 20 992 12-Dec-2023, 06:34 PM
Last Post: drumgod
  EMax Tinyhawk FREESTYLE III HDZero/ELRS BadRaven 1 412 27-Oct-2023, 08:07 AM
Last Post: BadRaven
  Tinyhawk Freestyle upgrades Rob Axel 4 323 05-Sep-2023, 09:40 PM
  Build 3” roninUAV Sohei MK2 Lemonyleprosy 211 13,937 20-Aug-2023, 11:55 AM
Last Post: iFly4rotors
  Diatone c25 mk2 3d print Wolfplay 0 191 16-Aug-2023, 08:08 PM
Last Post: Wolfplay
