Threads: 65
Likes Received: 3 in 3 posts
Likes Given: 19
0 Hey guys!
How would you calculate the expected increase in current when you increase the # of prop blades?
Say you have 3 blade and the motor draws 35A.. If you increased to a 5 blade prop (all else equal) what would the expected current be?
~58?
(35a x 1.66)
Threads: 92
27 Chris Rosser has whole video on this.
I think it was where he compared 7" props.
As you would expect, biblade wirh shallow pitch and small blade surface drew fewer amps... ie more efficient.
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 Current scales with prop diameter^4, so going from a 5" prop to a 3.5" prop, you'd expect to draw (3.5/5)^4 = 24% as much current, and going from 3 blades to 6 blades (6/3)=2 times as much current, so for your example going from 3 blade 5" props drawing 35A at a certain RPM, a 6 blade 3.5" prop at the same RPM would be expected to draw 35A * 24% * 2 = 16.8A.
Note that the thrust produced is proportional to the current drawn, and that smaller props and more blades are in general less efficient than larger props and fewer blades, so this setup would be expected to produce less than half as much thrust even though it is drawing about half the current.
What are you trying to accomplish here?
Threads: 172
Likes Given: 4,725
100 3,5" on 2207 motors, on a heavy build with ducts, will be extremly loud.
