ESC wiring question
I'm using the Lumenier 4Power PDB on my new build and as you can see by th pic, there's only a pad for the signal wire of the ESC but no ground.  So my question is, should I use signal wire only to the FC, or should I also use the ground.  And if I did, should I just connect it to the battery ground, or to a ground on the 4Power?  [Image: kGXYpKql.jpg]
I think i will connect the signal and ground wires directly to the FC and no signal wire on pdb. Imho
(21-May-2017, 04:39 PM)lorentz Wrote: I think i will connect  the signal and ground wires  directly to the FC  and no signal wire on pdb. Imho
Agreed, it'll be s little extra wiring but it's the correct way to do it.  My main concern will be trying to make everything fit as I've got it now with the receiver de-pinned and mounted between the FC and PDB and as you can see by the pic, even with all the wiring done, it makes for a very clean looking setup.[Image: 7Umxupxl.jpg]
[-] The following 3 users Like RENOV8R's post:
  • Drone0fPrey, Oscar, sloscotty
Wow! That looks really nice!
Super clean built! Really a good job!! And great color matching.
Thanks guys! I'm just on a smoke break, but I've switched to a typical wiring layout and still able to keep all the extra wiring pretty well organized. I've also switched out the RF Revolt for a BrainFPV RE1 fc, as I couldn't get the Revolt to show up in the receiver tab. Gotta go, my soldering iron is calling..........
[-] The following 2 users Like RENOV8R's post:
  • Drone0fPrey, unseen
wow man Smile Tell us how Stretched X flies compared to normal X Smile
I've been tempted to try that for a while!
Looking great man!
The Obsession IS Real!
I think I'll do a quick build thread (if I can get off my lazy ass) but probably just a few pics as JimmyLe already did an indepth review on the QAV-XS a while ago. But yes, you can tell this is a high quality frame as soon as you unpack it. Being a bottom-mounted battery, I'm pretty excited to see how it flies.
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 282 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 131 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 170 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 234 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 152 10-Mar-2024, 02:09 AM
