ESC for emax 2306 motors
Thinking about upgrading to the new emax 2306 motors but they pull 45amps on the top end. Just curious what ESC people are using to handle that much draw? I currently use racestar 30a v2 and I'm pretty sure the emax 2306 would fry them. Any help would be greatly appreciated.
They only pull 45A on a static thrust test.
I run my 2400kv ones with 6040 props and 4S on 30A ESCs with no problem at all.
(23-May-2017, 06:48 PM)unseen Wrote: They only pull 45A on a static thrust test.
Awesome! That's for the help, had no idea those manufacturer test were done on static setups
(23-May-2017, 07:12 PM)Nathaniel52441 Wrote: Awesome! That's for the help, had no idea those manufacturer test were done on static setups
All thrust tests are static thrust tests.
When looking at one, you should take 25 - 30% off from both thrust and current draw to get something closer to what you'll see in real life conditions.
  1102 motors on a 65mm pusher? ph2t 22 393 9 hours ago
Last Post: brettbrandon
  Ordered the HDZERO mob6 with the eco camera and 28k motors Rob Axel 35 1,055 21-Apr-2024, 06:25 PM
Last Post: iFly4rotors
  Build 1106 motors on 4S for a 2" prop mstc 10 206 19-Apr-2024, 06:30 PM
Last Post: mstc
  Can't get Emax Tinyhawk 3 HD into binding mode sharptailhunter 7 360 13-Apr-2024, 09:16 PM
Last Post: CDCMeteor75ProNewb
  Nice looking motors for a 3"er build skywanderer 3 177 17-Jan-2024, 11:00 PM
