15-Nov-2023, 01:11 PM (This post was last modified: 20-Jan-2024, 01:52 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. )
EDIT (20th January 2024): EdgeTX v2.9.3 is now available. See another thread HERE for details.
EdgeTX v2.9.2 ("Providence") was released a couple of days ago. Details and links are below.
- Release Notes: https://github.com/EdgeTX/edgetx/releases/tag/v2.9.2
- Installation Guide: https://github.com/.../edg.../wiki/EdgeTX-Installation-Guide
- Flash firmware via a Chrome based browser: https://buddy.edgetx.org/#/flash?version=v2.9.2
- SD Card Pack: https://github.com/EdgeTX/edgetx-sdcard/...tag/v2.9.0
- Sound Pack: https://github.com/EdgeTX/edgetx-sdcard-...tag/v2.9.0
- User Manual: https://edgetx.gitbook.io/edgetx-user-manual/v/v2.9
Quote:We are pleased to offer EdgeTX "Providence" v2.9.2, which fixes several small issues including mixer delay not working, copying models on B&W radios, allowing for startup/shutdown haptic to be disabled and adding support for configuration of some of the newer FrSky receivers, as well as some Companion fixes.
Warning
A bug in the behaviour of the 'delay' mixer option has been fixed whereby it would previously not function at all if the mix line was disabled for some flight modes. Please check your model to make sure it behaves correctly if you use the delay option or had configured it in the past and it didn't seem to be working!
What's Changed
RadioCompanion
- refactor(mixer): Improve mixer "delay" option (#4256)
- feat: Add support for OTA flashing and configuring newer FrSky receivers on ACCESS/ISRM radios (#4077)
- fix: Don't update (therefore deleting some settings) YAML files on SD card if radio in emergency mode (#4264)
- fix: Ext module not powered when using SBUS or CPPM trainer (#4167)
- fix(lua): insertMix function not working (#4129)
- fix(lua): Do not pass key event that triggered telemetry view to lua (#4168)
- fix(bw): Model copy going to wrong slot, refresh model headers (#4261)
- fix(color): No startup/shutdown haptic if haptic mode set to "quiet" (#4285)
- fix(color): 'SWITCH' widget option logic, enable for Lua widgets (#4190)
- fix(color): Value widget not refreshing when telem lost (#4223)
- fix(color): Refreshing of GPS and DATE_TIME telemetry when using Value Widget (#4250)
- fix(color): Reading of RGB theme colors in hex format (#4222)
- fix(color): 'Reset' SF does not show telemetry parameter when edited (#4237)
- fix(yaml): Do not limit to static MPM protocol definitions (#4146)
- fix: German voice fixes (Updating voice pack needed for full effect) (#3920, #4242, #4259)
Please refer to the following for the complete list of changes.
- fix(cpn): Default calibration values for 6POS switch (#4271)
- fix(cpn): Add back failsafe settings for protocols that support (#4220)
- fix(cpn): Non-functional edit model button and context menu entry (#4217)
Full Changelog: v2.9.1...v2.9.2
To learn more about new features, known issues, and other changes in 2.9.x, please see the release notes for v2.9.0
Supported radios
The full list of supported radios and their support status can be viewed here on the EdgeTX website.
Installation Guide
https://github.com/EdgeTX/edgetx.github.io/wiki/EdgeTX-Installation-Guide
Flash firmware via Chrome based browser
Unofficial builds
Multilingual and custom are available here. In the meantime, you can still build your own firmware online following this guide, request a specific build at #4000 or ask on Discord for someone to build one for you.
