Threads: 96
Likes Received: 531 in 218 posts
Likes Given: 188
20 for anyone planning on or is using these esc, may I suggest taking the heatshrink off of them and applying glue on the chip capacitors. they have a tendency to come loose even in minor crashes. I've already had to replace 2, and repair 1.
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 Could it be that the escs get hit by the propellers? I can see that the heatshrink on my escs are ripped up due to the props in a crash. Maybe they could be moved a little bit closer to the motors?
Threads: 96
Likes Given: 188
20 I had that happen to one where the prop knocked off 3 of the caps. but this last one the heatshrink was fine. I think I might split the case that it comes with and use it as a cover
Threads: 28
Likes Received: 75 in 34 posts
Likes Given: 30
2 I am using these
The dys xs30a blheli_S.
I am having an issue though not sure if it's the esc or what. The blackbox shows after a few mins of aggressive flying in a hard turn one of my motors will max out and I'll get an uncontrollable roll or almost anyways if I'm quick enough to catch it and I'm not in a bad spot.
I've done some research but I'm still having the issue.
I set my start up power to 1.25 as I've seen suggested.
I've calibrated them a few times.
Im just at a loss here.
Threads: 70
Likes Received: 742 in 378 posts
Likes Given: 577
44 Wasn't that 0.125 startup power?
Threads: 28
Likes Given: 30
2 I'm running 2k 2k and multishot .
I will change the start up power
Threads: 28
Likes Given: 30
2 Changed to .125 and solved this
