DJI air
Hello,
I want to tell you guys that I'm new in this hobby and I have some questions for you.
So  I have Holyro Kakute F7 V1.5 Flight Controler and I want to buy the DJI Unit but without receiver, I have Frsky taranis x9 lite S . I saw a lot of videos but I not sure where to connect the wires.
 Can I put the red wire to   B+? I use 4S battery. I know that the white wire will go to R1 and gray to T1.
The black will go to GND right above the B+?
But where to put the brown and yellow wires? Can you help me guys?
I'll appreciate if someone can help me with this.
Thanks a lot!
Are you just wanting to use the feed from the camera using your own transmitter? As far as i'm aware, you can just hook up the camera unit to power and be done with it, does the unit have instructions you can reference? Alternatively, Joshua Bardwell has a great library of videos for beginners! You should check him out on youtube. Smile
As long as you don't use more than 4S, you can wire the power (red) to B+. Ground to ground.
As for DJI UART RX and TX, the DJI UART RX goes to UART TX on FC. And DJI UART TX goes to UART RX. (I think you have it bavkward).
You don't need to wire the DJI HDL and signal ground because you will be using your Taranis.
  Hover stability of non-DJI drones KENN 6 168 20-May-2024, 06:31 PM
Last Post: SeismicCWave
  Dual antenna of OG Air Unit combined into one Fpv_Snidde 2 113 21-Apr-2024, 09:19 AM
Last Post: Fpv_Snidde
  Can I connect my DJI fpv v2 goggles to and dji fpv remote controller 2 to other drons qt179 4 293 08-Apr-2024, 10:57 AM
Last Post: roleyrev
  Camera View on DJI Fly for non-DJI drone fwpsam 2 210 01-Apr-2024, 05:43 PM
Last Post: fwpsam
  Second/alternate use for DJI RC2? butchalline 0 90 22-Mar-2024, 11:07 PM
Last Post: butchalline
