DIY a 6 Arm Soldering Stand
6 Arm Helping hand soldering station.
This is not a new must have tool but a DIY for one already mentioned.
Links for parts are below
It can be purchased on line.:
https://www.amazon.com/Soldering-Flexibl...8573&psc=1
https://www.alibaba.com/product-detail/W...86968.html
And elsewhere.
OR   I chose to DIY   Total cost about $15.
[Image: A1KWcThl.jpg]
It can be used with or with out the metal junction box
[Image: IZi9htll.jpg]
Easy to DIY
1. Drill 1/2" holes
2. Assemble arms to the base and tighten with nut.
3. Remove the last section of each arm and attach alligator clips
[Image: bWewPAPl.jpg]
For me the arms are a bit long but you can remove as many sections as you need to shorten them.
Flexible arms  $6.98
https://www.amazon.com/gp/product/B008O1...UTF8&psc=1
Aligator clips  $3.99
https://www.amazon.com/uxcell-Plastic-Ha...PMWN285VZH
4"x4" Metal junction box and lid  $2.99
6  1/2"x20 Nuts  $0.80
NOTE:
(i searched the forum a DIY like this but came up empty. If someone finds an earlier DIY post please let me know and I will delete this one)
[-] The following 7 users Like roger74's post:
  • raspberrypi33, Deal-E-O, Oscar, Krohsis, sloscotty, hugnosed_bat, SnowLeopardFPV
Very cool.
Nicely done.....
Roger74, is the weight enough? On my store bought helping hands, I wish the center block would weight a little more.
I guess you could always fill the base with sand, lead, or some other densely weighted material.
(28-Nov-2019, 05:54 PM)SnowLeopardFPV Wrote: I guess you could always fill the base with sand, lead, or some other densely weighted material.
Yeah lead shot might work nicely.
Throw a neodymium magnet under that plate, for managing loose hardware. They are heavy enough to help offer some weight too.
(28-Nov-2019, 05:36 PM)voodoo614 Wrote: Roger74, is the weight enough? On my store bought helping hands, I wish the center block would weight a little more.
First let me apologize, i just now saw your question.
Yes, the weight of the  4" box has been enough to keep it stable. I usually extend the arms out away from the box when working but
i am only holding a FC board so tipping over hasnt been an issue.
IF YOU BUILD IT, IT WILL CRASH
Great
  Dreamy magnification for soldering! skywanderer 5 941 22-Oct-2023, 04:56 PM
Last Post: skywanderer
  Tip & Trick Enclosure Box for Power Supply 350W DIY Zorik_IL 3 583 30-Oct-2022, 01:32 AM
  Sequre A110 soldering iron was defective and they want me to attempt to repair it?? Rob3ddd 8 1,722 23-Jul-2021, 03:25 AM
Last Post: Rob3ddd
  Tip & Trick Soldering for novices Titanv11 14 1,677 13-Mar-2021, 03:33 AM
  Smoke Stopper Alternative - No DIY required Oscar 0 901 09-Jul-2020, 10:12 PM
Last Post: Oscar
