Hi Everyone, I have upgraded my R349 to Betaflight 4.2 against my better judgement i also upgraded my esc's to Jesc and reversed the motor direction on all motors and set the same in betaflight.
but now the quad is freaking out when i arm and raise the throttle i'm not sure what to look at now here's my dump file i wonder if anyone cant spot what im doing wrong.
thanks
# dump
# Betaflight / STM32F405 (S405) 4.2.0 Jun 14 2020 / 03:04:22 (8f2d21460) MSP API: 1.43
# config: manufacturer_id: DIAT, board_name: FURYF4OSD, version: 3a35e73b, date: 2019-09-30T05:46:12Z
# start the command batch
batch start
board_name FURYF4OSD
manufacturer_id DIAT
# name: R349
# resources
resource BEEPER 1 A08
resource MOTOR 1 A03
resource MOTOR 2 B00
resource MOTOR 3 B01
resource MOTOR 4 A02
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 C09
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource SONAR_TRIGGER 1 NONE
resource SONAR_ECHO 1 NONE
resource LED_STRIP 1 A00
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 NONE
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 NONE
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 C00
resource INVERTER 2 NONE
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 B06
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 B07
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 B05
resource LED 2 B04
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource TRANSPONDER 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 C09
resource CAMERA_CONTROL 1 B09
resource ADC_BATT 1 C01
resource ADC_RSSI 1 C02
resource ADC_CURR 1 C03
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource COMPASS_CS 1 NONE
resource COMPASS_EXTI 1 NONE
resource SDCARD_CS 1 NONE
resource SDCARD_DETECT 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 B03
resource OSD_CS 1 B12
resource RX_SPI_CS 1 NONE
resource RX_SPI_EXTI 1 NONE
resource RX_SPI_BIND 1 NONE
resource RX_SPI_LED 1 NONE
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 C05
resource VTX_POWER 1 NONE
resource VTX_CS 1 NONE
resource VTX_DATA 1 NONE
resource VTX_CLK 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer A03 AF1
# pin A03: TIM2 CH4 (AF1)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF1
# pin B01: TIM1 CH3N (AF1)
timer A02 AF1
# pin A02: TIM2 CH3 (AF1)
timer A00 AF2
# pin A00: TIM5 CH1 (AF2)
timer B09 AF3
# pin B09: TIM11 CH1 (AF3)
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin C09 0
dma pin A03 1
# pin A03: DMA1 Stream 6 Channel 3
dma pin B00 0
dma pin B01 0
# pin B01: DMA2 Stream 6 Channel 0
dma pin A02 0
# pin A02: DMA1 Stream 1 Channel 3
dma pin A00 0
dma pin B09 NONE
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mixer
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon RX_SET
# map
map TAER1234
serial 2 2048 115200 57600 0 115200
serial 5 64 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1950 2100 0 0
aux 1 1 1 1925 2100 0 0
aux 2 2 1 1425 1550 0 0
aux 3 13 2 1975 2100 0 0
aux 4 35 2 900 1075 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable band 3 BOSCAM_E E CUSTOM 5705 5685 5665 0 5885 5905 0 0
vtxtable band 6 IMD6 I CUSTOM 5732 5765 5828 5840 5866 5740 0 0
vtxtable powerlevels 4
vtxtable powervalues 0 1 2 3
vtxtable powerlabels 25 200 500 800
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 200
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 250
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_q = 250
set dyn_notch_min_hz = 70
set dyn_notch_max_hz = 350
set dyn_lpf_gyro_min_hz = 200
set dyn_lpf_gyro_max_hz = 500
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set acc_calibration = -198,78,-282,1
set align_mag = DEFAULT
set mag_align_roll = 0
set mag_align_pitch = 0
set mag_align_yaw = 0
set mag_bustype = SPI
set mag_i2c_device = 0
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_hardware = NONE
set mag_declination = 0
set mag_calibration = 0,0,0
set baro_bustype = SPI
set baro_spi_device = 0
set baro_i2c_device = 0
set baro_i2c_address = 0
set baro_hardware = NONE
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_src_frame_errors = ON
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 20
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set srxl2_unit_id = 1
set srxl2_baud_fast = ON
set sbus_baud_fast = OFF
set crsf_use_rx_snr = OFF
set serialrx_halfduplex = OFF
set rx_spi_bus = 0
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 300
set dshot_burst = OFF
set dshot_bidir = ON
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 12
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_max_cell_voltage = 435
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = ON
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 179
set gps_provider = NMEA
set gps_sbas_mode = NONE
set gps_sbas_integrity = OFF
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_use_3d_speed = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 2
set thrust_linear = 0
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set sdcard_mode = OFF
set sdcard_dma = OFF
set sdcard_spi_bus = 0
set sdio_clk_bypass = OFF
set sdio_use_cache = OFF
set sdio_use_4bit_width = OFF
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_warn_rssi = OFF
set osd_warn_over_cap = OFF
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 2068
set osd_link_quality_pos = 2104
set osd_rssi_dbm_pos = 2072
set osd_tim_1_pos = 234
set osd_tim_2_pos = 2551
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 2048
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14665
set osd_avg_cell_voltage_pos = 2496
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = ON
set osd_stat_battery = ON
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set osd_stat_min_link_quality = ON
set osd_stat_max_fft = OFF
set osd_stat_total_time = ON
set osd_stat_total_dist = OFF
set osd_stat_min_rssi_dbm = ON
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 5
set vtx_channel = 8
set vtx_power = 2
set vtx_freq = 5917
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vtx_spi_bus = 0
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set frsky_spi_autobind = OFF
set frsky_spi_tx_id = 0,0
set frsky_spi_offset = 0
set frsky_x_rx_num = 0
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 1800
set gyro_2_bustype = SPI
set gyro_2_spibus = 1
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_overclock = ON
set i2c2_pullup = OFF
set i2c2_overclock = ON
set i2c3_pullup = OFF
set i2c3_overclock = ON
set mco2_on_pc9 = OFF
set gyro_rpm_notch_q = 500
set gyro_rpm_notch_min = 100
set dterm_rpm_notch_q = 500
set dterm_rpm_notch_min = 100
set rpm_notch_lpf = 150
set flysky_spi_tx_id = 0
set stats = OFF
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set name = R349
set display_name = -
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = -
set dyn_lpf_dterm_min_hz = 70
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 150
set dterm_lowpass2_type = PT1
set dterm_lowpass2_hz = 150
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_gain = 3500
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 15
set iterm_windup = 100
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 46
set i_pitch = 90
set d_pitch = 38
set f_pitch = 95
set p_roll = 42
set i_roll = 85
set d_roll = 35
set f_roll = 90
set p_yaw = 45
set i_yaw = 90
set d_yaw = 0
set f_yaw = 90
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 23
set d_min_pitch = 25
set d_min_yaw = 0
set d_min_boost_gain = 37
set d_min_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set ff_spike_limit = 60
set ff_max_rate_limit = 100
set ff_smooth_factor = 37
set ff_boost = 15
set idle_min_rpm = 0
set idle_p = 50
set idle_pid_limit = 200
set idle_max_increase = 150
set level_race_mode = OFF
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_breakpoint = 1350
set tpa_mode = D
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
thanks
# dump
batch start
# name: R349
# resources
resource PPM 1 C09
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED 1 B05
resource LED 2 B04
resource LED 3 NONE
# timer
timer C09 AF3
timer A03 AF1
timer B00 AF2
timer B01 AF1
timer A02 AF1
timer A00 AF2
timer B09 AF3
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin C09 0
dma pin A03 1
dma pin B00 0
dma pin B01 0
dma pin A02 0
dma pin A00 0
dma pin B09 NONE
# mixer
mixer QUADX
# servo
# servo mixer
smix reset
feature -OSD
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature RX_SERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper CRASH_FLIP
# beacon
beacon -RX_LOST
beacon RX_SET
# map
map TAER1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 6
vtxtable channels 8
# vtx
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set acc_lpf_hz = 10
set rssi_offset = 0
set rx_spi_bus = 0
set adc_device = 1
set ibatv_scale = 0
set beeper_od = OFF
set deadband = 0
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_ah_pos = 78
set osd_profile = 1
set vtx_band = 5
set vtx_channel = 8
set vtx_power = 2
set vtx_freq = 5917
set vtx_spi_bus = 0
set stats = OFF
set name = R349
# profile 0
set acc_limit = 0
set crash_delay = 0
set p_pitch = 46
set i_pitch = 90
set d_pitch = 38
set f_pitch = 95
set p_roll = 42
set i_roll = 85
set d_roll = 35
set f_roll = 90
set p_yaw = 45
set i_yaw = 90
set d_yaw = 0
set f_yaw = 90
set d_min_roll = 23
set d_min_yaw = 0
set ff_boost = 15
set idle_p = 50
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 65
set tpa_mode = D
batch end
