Hello everyone!
I got my hands on a brand new SpeedyBee F405 V3 + BLS 50A Stack and I've run into my first obstacle!
I haven't upgraded my Radio system yet and I'm still using my FlySKY CT6B Tx and R6B Rx. Since the F405 flight controller doesn't take in PWM RC Input, I bought an 8 channel PPM encoder.
Link: https://robu.in/product/pixhawk-ppm-enco...lQQAvD_BwE
I connected the R6B's channels 1-4 to the PWM inputs 1-4 of the PPM encoder and the PPM output to R2 on my flight controller.
I enabled Serial RX on UART 2 on the betaflight configurator.
Under the RECEIVERS tab, I selected the receiver type as PPM/CPPM and selected the default channel mapping (AETR1234)
Here's what I'm observing:
Case1) All 4 channels connected between the PPM encoder and Receiver:
Only the right gimbal movements (Roll and Pitch) are recognized by betaflight
Left gimbal movements (Throttle and Yaw) don't work and are always at their lowest position (around 1050)
3D model of the quad keeps spinning left because of this
Case2) Only channels 1,2 and 4 are connected between the PPM encoder and Receiver:
All the three stick movements (Roll, Pitch and Yaw) are recognized by betaflight
Case3) Only channel 3 is connected between the PPM encoder and Receiver:
Throttle stick movement is recognized by betaflight
I am using DigitalRadio with the Tx connected to my PC to check the RC Output simultaneously and everything seems to be working fine there! All the stick movements and the auxiliary channels (5 and 6) are recognized!
I have also tested the same on the latest betaflight firmware (4.4.2) and the problem still persists
I did an extensive search on the internet and couldn't find a single person facing the same issue! Most of the videos/threads talk about absolutely not getting the receiver to work with betaflight.
This issue has been eating up my head for a good couple of hours now and it's starting to get really frustrating!
Any help regarding this would be much appreciated as investing so much money in a new stack would end up being useless if I can't even get the radio link setup properly! Maybe I should try using an S BUS receiver and compatible transmitter but I can't afford a new radio system right now!
Everything else like the baro, accel, gyro, current and voltage sensors are working just fine! I just want to get the receiver up and running so I can get back in the air!
