Defective Battery?
I recently bought a couple of 3s batteries in anticipation of getting my new quad. The batteries showed up and one of them isn't registering voltage right.
When I put my charger on the battery meter it only registers one cell @ like 3.7v if I remember correctly when checking the balance lead and when checking the main lead it's less than 7v (which doesn't check out with the previous reading)
Is this something I can fix somehow or do I have a DOA battery and should get in touch with the manufacturer?
The other battery reads as expected and is charging to storage charge now without any problems.
Readings from balance lead:
0.00 0.00 3.71 V
0.00 0.00 0.00 V
Readings from main lead:
Main 6.55V
carl.vegas
I would try to slowly balance charge but keep an eye on it...
Disclaimer: the following might be risky, but:
If it's too low cell voltage for the charger to recognize the battery right, you could give it a short charge with a lead battery program, if your charger supports this, just to get the voltage up a bit.
But get in contact with seller anyway, i'd consider this as defect.
EDIT: yeah if it shows 0.0 volts there's no hope... Like Oscar says below, probably broken soldering or contacts.
  • Carl.Vegas
sounds like some of the battery balance wires might have broken solder joints?
I would probably contact seller and arrange replacement... take pictures of the readings as proof... (take one that has the correct reading so they know your equipment are working)
  • Carl.Vegas
Gotcha, I'll start with Turnigy. I'd go back to Amazon but it's through an unusual seller and sometimes returns go a little fishy.
Thanks guys!
carl.vegas
  Discussion 4-6s battery charger advice balauru_327 11 515 19-Feb-2024, 03:57 PM
Last Post: jasc
  Li-ion Battery and Betaflight mlcasmey 11 1,237 26-Jan-2024, 01:18 AM
Last Post: StuweFPV
  Discussion Battery Dimensions segler999 2 216 19-Jan-2024, 05:39 PM
Last Post: segler999
  Need help finding battery replacement for T-drones Ares 6S 30Ah on US east coast Heimegut 1 221 15-Jun-2023, 10:46 PM
Last Post: Lemonyleprosy
  Help Battery dent Akuzo 10 1,008 06-Jun-2023, 02:07 PM
Last Post: EyeBotXander
