Custom micro quad crazy yaw spin
I JUST got my quad working fully (Quanum Pico + Turnigy 9xr with OrangeRx module) thanks to sloscotty.
When I take off, the quad just goes into a crazy yaw spin.  I've tried trimming via the TX but that doesn't help.  I've tried manually applying opposite yaw, but that just makes it spin the other direction.
I THINK the problem might be that I have the motors on backwards.  Normally motors spin inward toward the body of the quad, but mine are all swapped so that they spin outwards away from the body.  Would this be the cause of my yaw problem?  I'm double checking before I try to go soldering the tiny wires again because I think it was a miracle I got them connected last time without any screwups.
If your motors aren't turning the correct direction, you'll want to fix that first (and make sure propellers are correct as well):
(from above)
CW-----CCW
CCW-----CW
If those are correct, try reversing channel 4 on your transmitter.
It was the motor directions. They were all spinning exactly opposite from what they should. Flipped them around and it flies like a dream!
[-] The following 1 user Likes jamesw's post:
  • sloscotty
Aha Big Grin that's good to know! how did you change spin direction, swap the motor wires?
(13-Jul-2016, 03:02 PM)jamesw Wrote: It was the motor directions.  They were all spinning exactly opposite from what they should.  Flipped them around and it flies like a dream!
Great jamesw!  Good that it is finally flying!!
(13-Jul-2016, 03:08 PM)Oscar Wrote: Aha Big Grin that's good to know! how did you change spin direction, swap the motor wires?
Just swapped the motors!
Moved back ones to front and front ones to back.
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 602 23-Apr-2024, 08:08 PM
Last Post: segler999
  Build Low profile 3 inch prototype quad design ph2t 24 751 11-Mar-2024, 03:53 PM
Last Post: skywanderer
  Help Micro Quad flying easy but wobbling Harry1 46 1,423 13-Feb-2024, 10:18 PM
  Discussion Walksnail Avatar Goggles & Quad Combo (Axisflying Cineon Z25) QuadFlyer68 108 7,150 23-Dec-2023, 01:10 AM
Last Post: lyoha
  GEPRC TinyGo for a first FPV quad? Scro 5 490 19-Dec-2023, 11:59 PM
Last Post: mstc
