Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 20-Mar-2020, 03:44 PM Hey all, very sorry but I am once again back! Got a tbs crossfire system (micro tx + micro rx v2) today and I'm having a few issues with it. I wired in my crossfire micro rx v2 correctly, with CH1 to rx etc, and I bound the receiver to my qx7s fine (did also adjust the baud rate). I can configure the receiver from the radio and I do get RSSI feedback so I know its working. However, I don't get any stick inputs in betaflight? I've wired it up to tx6/rx6, set serial rx on for that uart. Set the protocol as CRSF in betaflight and the radio. The micro tx is also set to output CRSF TX to rx and CRSF RX to tx correctly. I've updated firmware for the transmitter/receiver and nothing still. Also tried doing it with a LiPo plugged in and nothing. Help please! If it helps, I have an emax buzz and here's the flight controller diagram: https://emax-usa.com/download/Buzz_I...anual_v1.3.pdf Thanks so much in advance! • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 Did you create a model in your QX7? You might need to redo your mixer settings again. The ground is for dead people. • Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 (20-Mar-2020, 04:05 PM)Banelle Wrote: Did you create a model in your QX7? You might need to redo your mixer settings again. I've used the same model as I've always done, which worked on my R9M and xm+, would I need to create another model? • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 (20-Mar-2020, 04:10 PM)damajesticmuffin Wrote: I've used the same model as I've always done, which worked on my R9M and xm+, would I need to create another model? If you changed an existing model to use Crossfire then you shouldn't need to set up the channels and mixer again. Could you post a dump from the Betaflight CLI? The ground is for dead people. • Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 (20-Mar-2020, 05:12 PM)Banelle Wrote: If you changed an existing model to use Crossfire then you shouldn't need to set up the channels and mixer again. Could you post a dump from the Betaflight CLI? It didn't let me post all of it because too many characters so I had to make a google document instead, sorry https://docs.google.com/document/d/1AxAP...sp=sharing • Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 Hmm, your config looks fine. Is it definitely wired to UART6? I couldn't see any pads for it, unless you're stealing the wires from the VTX header? The ground is for dead people. • Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 20-Mar-2020, 06:09 PM (This post was last modified: 20-Mar-2020, 06:12 PM by damajesticmuffin.) (20-Mar-2020, 06:02 PM)Banelle Wrote: Hmm, your config looks fine. Is it definitely wired to UART6? I couldn't see any pads for it, unless you're stealing the wires from the VTX header? Yep it's wired to UART6, I removed the smart audio since I don't ever use it. The plug that the crossfire came with had pins inside the header which also fit into the vtx header plug, so I took the individual pins out and put them in there. I did the same with my R9MM and it worked (however I did solder the wires together, not put the pin inside the header for the r9mm) • Posts: 21,190 Threads: 582 Likes Received: 8,930 in 6,606 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 Your problem is that you've re-mapped the original resource (C07) for "SERIAL_RX 6" to "SERVO 1". So you no longer have a full RX/TX functionality on UART6. Is there any reason you've done that? Are you trying to use a servo for something? Quote:# resources resource BEEPER 1 B04 resource MOTOR 1 B00 resource MOTOR 2 B01 resource MOTOR 3 A03 resource MOTOR 4 A02 resource MOTOR 5 A01 resource MOTOR 6 A08 resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 C07 resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 B14 resource PWM 1 B14 resource PWM 2 B15 resource PWM 3 C06 resource PWM 4 NONE resource PWM 5 C08 resource PWM 6 C09 resource PWM 7 NONE resource PWM 8 NONE resource SONAR_TRIGGER 1 A01 resource SONAR_ECHO 1 A08 resource LED_STRIP 1 A01 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 NONE resource SERIAL_TX 3 B10 resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 C06 resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 NONE resource SERIAL_RX 3 B11 resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE Posts: 1,312 Threads: 50 Likes Received: 832 in 504 posts Likes Given: 372 Joined: Jul 2018 Reputation: 51 Oh wow - well spotted. The ground is for dead people. • Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 (20-Mar-2020, 06:12 PM)SnowLeopardFPV Wrote: Your problem is that you've re-mapped the original resource (C07) for "SERIAL_RX 6" to "SERVO 1". So you no longer have a full RX/TX functionality on UART6. Is there any reason you've done that? Are you trying to use a servo for something? Oops! Well however I did that, I certainly did not mean to since I have no servos! How do I change it back? • Posts: 21,190 Threads: 582 Likes Received: 8,930 in 6,606 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 If you run the following commands in the CLI, that will fix it... Code: resource SERVO 1 NONE resource SERIAL_RX 6 C07 save
• Posts: 66 Threads: 14 Likes Received: 4 in 3 posts Likes Given: 10 Joined: Jun 2019 Reputation: 0 (20-Mar-2020, 06:44 PM)SnowLeopardFPV Wrote: If you run the following commands in the CLI, that will fix it... Code: resource SERVO 1 NONE resource SERIAL_RX 6 C07 save
Thank you both! You're both lifesavers and I don't know what I would do without this website!!! Works a treat now Posts: 2 Threads: 0 Likes Received: 2 in 2 posts Likes Given: 0 Joined: Aug 2020 Reputation: 0 16-Aug-2020, 07:08 PM Hey guys, I'm having a similar issue. I went through the CLI dump but everything seems fine. Can you please check over my CLI dump to see if you can spot something? I have the Crossfire Nano RX set to UART3 and wired to RX3 and TX3 on a XILO F4 board. Thanks in advance here is the CLI dump since it's too long to post on here https://docs.google.com/document/d/16qNA...sp=sharing Posts: 21,190 Threads: 582 Likes Received: 8,930 in 6,606 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 (16-Aug-2020, 07:08 PM)THEGEEK19 Wrote: Hey guys, I'm having a similar issue. I went through the CLI dump but everything seems fine. Can you please check over my CLI dump to see if you can spot something? I have the Crossfire Nano RX set to UART3 and wired to RX3 and TX3 on a XILO F4 board. Thanks in advance Run the following commands in the CLI and then check for stick movements again in the Receiver tab... Code: serial 0 0 115200 57600 0 115200 save
• Posts: 2 Threads: 0 Likes Received: 2 in 2 posts Likes Given: 0 Joined: Aug 2020 Reputation: 0 (16-Aug-2020, 07:12 PM)SnowLeopardFPV Wrote: Run the following commands in the CLI and then check for stick movements again in the Receiver tab... Code: serial 0 0 115200 57600 0 115200 save
Worked like a charm. Thank you so much for the quick reply! |
