Hi all,
I have been following Chris Rosser's BF 4.3 Tuning Guide, but ran into a problem when entering certain CLI commands, e.g., set rpm_filter_min_hz = 100 or set rpm_filter_fade_range_hz = 100. The message I get is the following: ERROR IN set: INVALID NAME. Any idea why this command is not being recognized by BF? The following post suggests that commands such as these were working since March 14th at the latest: https://intofpv.com/t-meteor-65pro-elrs-...figuration. Attached is my "diff all" if that would be of use.
Thanks,
Jack
Thanks,
Jack
