Full review: https://oscarliang.com/flywoo-flylens75/
defaults nosave
###WARNING: NO CUSTOM DEFAULTS FOUND###
# Betaflight / STM32F405 (S405) 4.4.2 May 31 2023 / 22:53:28 (23d066d) MSP API: 1.45
###ERROR IN diff: NO CONFIG FOUND###
# start the command batch
batch start
defaults nosave
board_name FLYWOOF405S_AIO
manufacturer_id FLWO
mcu_id 004d004a4e50501020383236
signature
# resources
resource BEEPER 1 C13
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 A03
resource MOTOR 4 A02
resource MOTOR 5 B05
resource MOTOR 6 B07
resource MOTOR 7 C09
resource MOTOR 8 C08
resource PPM 1 B08
resource LED_STRIP 1 A09
resource SERIAL_TX 1 B06
resource SERIAL_TX 2 D05
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 6 C06
resource SERIAL_RX 1 A10
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource I2C_SCL 1 B08
resource I2C_SDA 1 B09
resource LED 1 C14
resource SPI_SCK 1 A05
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 B08
resource ADC_BATT 1 C03
resource ADC_RSSI 1 C00
resource ADC_CURR 1 C02
resource PINIO 1 D06
resource FLASH_CS 1 B03
resource OSD_CS 1 B14
resource GYRO_EXTI 1 B13
resource GYRO_CS 1 B12
resource USB_DETECT 1 A08
# timer
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer A03 AF1
# pin A03: TIM2 CH4 (AF1)
timer A02 AF1
# pin A02: TIM2 CH3 (AF1)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer A09 AF1
# pin A09: TIM1 CH2 (AF1)
# dma
dma ADC 1 0
dma pin B00 0
dma pin B01 0
dma pin A03 1
# pin A03: DMA1 Stream 6 Channel 3
dma pin A02 0
# pin A02: DMA1 Stream 1 Channel 3
dma pin B05 0
dma pin B07 0
dma pin C09 0
dma pin C08 0
dma pin A09 0
feature LED_STRIP
feature OSD
serial 5 131073 115200 57600 0 115200
led 0 7,6::CO:11
led 1 8,6::CO:11
aux 0 0 2 1300 2100 0 0
aux 1 2 2 1700 2100 0 0
aux 2 35 3 1700 2100 0 0
# master
set dyn_notch_min_hz = 60
set dyn_notch_max_hz = 300
set acc_calibration = 48,24,33,1
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 1
set serialrx_provider = CRSF
set dshot_idle_value = 800
set dshot_burst = ON
set dshot_bidir = ON
set motor_poles = 12
set motor_output_reordering = 1,0,3,2,4,5,6,7
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 170
set beeper_inversion = ON
set beeper_od = OFF
set yaw_motors_reversed = ON
set pid_process_denom = 4
set osd_warn_bitmask = 8063
set osd_vbat_pos = 2402
set osd_link_quality_pos = 2146
set osd_tim_1_pos = 2423
set osd_tim_2_pos = 2391
set osd_flymode_pos = 2296
set osd_throttle_pos = 2327
set osd_current_pos = 2305
set osd_mah_drawn_pos = 2337
set osd_warnings_pos = 14729
set osd_avg_cell_voltage_pos = 2370
set osd_core_temp_pos = 2263
set osd_displayport_device = MSP
set osd_canvas_width = 30
set osd_canvas_height = 13
set system_hse_mhz = 8
set max7456_spi_bus = 3
set dashboard_i2c_bus = 1
set pinio_box = 40,41,255,255
set flash_spi_bus = 3
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_sensor_align = CW180FLIP
set gyro_1_align_pitch = 1800
set gyro_1_align_yaw = 1800
set gyro_2_spibus = 1
# profile 0
set dterm_lpf1_static_hz = 0
set iterm_relax_cutoff = 25
set p_pitch = 63
set i_pitch = 124
set d_pitch = 73
set f_pitch = 149
set p_roll = 60
set i_roll = 118
set d_roll = 62
set f_roll = 143
set p_yaw = 60
set i_yaw = 118
set f_yaw = 143
set d_min_roll = 60
set d_min_pitch = 71
set thrust_linear = 20
set feedforward_averaging = 2_POINT
set feedforward_smooth_factor = 60
set feedforward_jitter_factor = 10
set simplified_i_gain = 110
set simplified_d_gain = 200
set simplified_pi_gain = 135
set simplified_dmax_gain = 10
set simplified_feedforward_gain = 120
set simplified_pitch_d_gain = 105
profile 1
profile 2
profile 3
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
