China on Monday announced export controls on some drones and drone-related equipment, saying it wanted to safeguard "national security and interests" amid escalating tension with the United States over access to technology. These new restrictions will come into effect on 1st Sep, 2023.
Quote:Items meeting the following characteristics shall not be exported without permission:Edit: Found some additional restrictions:
- Aeroengines with a maximum continuous power exceeding 16 kilowatts (kW) dedicated to specific unmanned aerial vehicles or unmanned airships (refer to customs commodity numbers: 8501200010, 8501320010, 8501330010, 8501340010, 8501400010, 8501520010, 8501530010, 840710 1010, 8407102010, 8408909230, 8408909320, 8411111010, 8411119010, 8411121010, 8411129020, 8411210010, 8411221010, 8411222010, 8411223010, 8411810002).
- Payloads specially used for specific unmanned aerial vehicles or unmanned airships that meet certain technical indicators, including infrared imaging equipment, synthetic aperture radar, and lasers for target indication.
- 1. Infrared imaging equipment with any of the following characteristics (refer to customs commodity numbers: 8525891110, 8525892110, 8525893110):
- The wavelength range is between 780 nanometers (nm) and 30000 nanometers (nm);
- The instantaneous field of view (IFOV) is less than 2.5 milliradians (mrad).
- Synthetic aperture radar (SAR) with an operating range greater than 5 kilometers (km) and any of the following characteristics (refer to customs commodity number: 8526109011):
- The strip mode resolution is better than 0.3 meters (m);
- The beamforming mode resolution is better than 0.1 meter (m).
- A laser for target indication that can work stably in an environment higher than 55 degrees Celsius (°C) and has any of the following characteristics (refer to the customs commodity number: 9013200093):
- Free temperature control type;
- Energy greater than 80 millijoules (mJ);
- The stability is better than 15%;
- The beam divergence angle is less than 0.3 milliradians (mrad).
- Radio communication equipment dedicated to specific unmanned aerial vehicles or unmanned airships and having any of the following characteristics (refer to customs commodity numbers: 8517629910, 8517691002, 8526920010):
- The transmission distance of wireless TV is greater than 50 kilometers (km);
- One station can control more than 10 machines.
- Civil anti-drone systems:
- Anti-drone electronic jamming equipment with a jamming range greater than 5 kilometers (km) (refer to the customs commodity number: 8543709960);
- High-power lasers with an output power greater than 1.5 kilowatts (kW) specially used in anti-drone systems (refer to customs commodity number: 9013200093).
Quote:Unmanned aerial vehicles whose performance indicators do not meet the existing control indicators but have reached the following indicators (refer to customs commodity numbers: 8806100010, 8806221011, 8806229010, 8806231011, 8806239010, 8806241011, 8806249010, 8806291011, 880629 9010, 8806921011, 8806929010 , 8806931011, 8806939010, 8806941011, 8806949010, 8806990010), without permission, shall not be exported:
It is capable of controllable flight beyond the operator's natural sight distance, the maximum endurance time is greater than or equal to 30 minutes, and the maximum take-off weight is greater than 7 kilograms (kg) or the empty weight is greater than 4 kilograms (kg), and has any of the following characteristics Manned aerial vehicle or unmanned airship:
- The power of airborne radio equipment exceeds the power limit value of international civilian radio product approval and certification;
- Carrying a load with a throwing function or bringing its own throwing device;
- Carrying a hyperspectral camera, or a multispectral camera that supports bands other than 560 nanometers (nm), 650 nanometers (nm), 730 nanometers (nm), and 860 nanometers (nm);
- The noise equivalent temperature difference (NETD) of the infrared camera carried is less than 40 millikelvin (mK);
- The laser ranging and positioning module carried meets any of the following requirements:
- The laser ranging and positioning module carried belongs to the 3R, 3B or 4 laser products stipulated in GB7247.1-2012;
- The laser ranging and positioning module carried belongs to the Class 1 laser product specified in GB7247.1-2012. At the same time, the attainable emission limit (AEL) is greater than or equal to 263.89 nanojoules (nJ), and the reference aperture is greater than 22 millimeters (mm). The maximum emission power of laser pulses within nanoseconds is greater than 52.78 watts (W);
- The laser ranging and positioning module carried belongs to the 1M class of laser products stipulated in GB7247.1-2012. At the same time, the attainable emission limit (AEL) is greater than or equal to 339.03 nanojoules (nJ), and the reference aperture is greater than 19 millimeters (mm). The maximum emission power of laser pulses in nanoseconds is greater than 67.81 watts (W).
