Caddx Vista camera not in focus
Hi guys,
So I was building a new drone (AOS 5.5, really cool) and I used a Caddx Vista camera I had lying around. After setting up, I noticed the video is only in focus for objects really close by. During flying where the focus is on the landscape, the video is very blurry, making it impossible to fly properly.
Any idea if the focus of the Caddx Vista can be adjusted or is this camera doomed?
Cheers
The lens is screw on, at least on my Polar Starlight which is the only camera I've had to replace the lens on. I needed to screw on the lens and watch video at the same time in order to get it properly focused.
[-] The following 1 user Likes Mike C's post:
  • Geeseemax
If it’s an original DJI style camera (two screw mounting holes on either side) then you may have to gently heat up the lens to adjust it, on those originals they thread locked the lenses in.
Hairdryer usually does the trick. On newer Caddx stuff they have a locking ring that you undo and hen you can adjust the focus that way, as Mike C said, gotta have 5 hands and be looking through googles too.
[-] The following 1 user Likes IanS's post:
  • Suros
Photo GetFPV and Caddx Walksnail - RMA Denial athaemik 11 253 20-Apr-2024, 03:25 PM
  Meteor 65 pro replacement camera NewToFPV 19 449 19-Apr-2024, 06:19 AM
Last Post: NewToFPV
  Swapping Caddx camera's Jelle 1 104 16-Apr-2024, 10:48 AM
  Camera View on DJI Fly for non-DJI drone fwpsam 2 170 01-Apr-2024, 05:43 PM
Last Post: fwpsam
Exclamation Analog Camera Question / SBF7V3 Coleon 4 288 20-Feb-2024, 08:38 PM
Last Post: Coleon
