Posts: 171 Threads: 31 Likes Received: 8 in 8 posts Likes Given: 37 Joined: Apr 2023 Reputation: 0 10-Feb-2024, 11:56 PM 5V - Power GND - Ground Video - Yellow Blue - CC ( ???? ) Hay Everyone.. Just another Stupid Noob Question from yours truly..lol I have an older 3 wire Analog (TU or TV 1200) Camera that came with one of my Walkera F-210 Quads, And those Cam's are 3 wire. Pwr, Gnd and Video. On the F7, The Analog camera Port has a 4 pin connector. The 4th wire on the F7 is Blue and labeled CC.??? ---------------------------------------------------------------------------------------------------------------------------------- * Whats the CC stand for? * Am I gonna be able to use this camera for a temporary situation? (Almost got the finds for an Air Unit) * Or should I just wait till I can put in an Air Unit? -Thanks • Posts: 2,377 Threads: 74 Likes Received: 1,337 in 997 posts Likes Given: 781 Joined: Apr 2022 Reputation: 41 11-Feb-2024, 04:47 AM (This post was last modified: 11-Feb-2024, 04:48 AM by Pathfinder075.) Generally you connect Cam to the Video in pad on the FC, then Video out goes to the VTX. But on some VTX you send Cam to the VTX and let it handle the sending to the FC. So the Happymodel VTX (Diamond and Whoop) do it the, IMO, easier way, where the cam output goes to the VTX first. Also other similar VTX that have the two plug system. So as to your question, my guess is cam is Video in and CC is video out, because the other two are power. But that would also suggest you have an analogue port for the VTX. If you do have a separate connector for the VTX, then ignore CC and wire the cam to cam and power to power. Ok I learned something new. CC is for the menu pin on the camera, the one you use to get OSD and change camera options, which i've never bothered doing so far. Your camera has no menu pin, so ignore that wire. Try Not, Do or Do Not - Yoda Posts: 171 Threads: 31 Likes Received: 8 in 8 posts Likes Given: 37 Joined: Apr 2023 Reputation: 0 (11-Feb-2024, 04:47 AM)Pathfinder075 Wrote: Generally you connect Cam to the Video in pad on the FC, then Video out goes to the VTX. But on some VTX you send Cam to the VTX and let it handle the sending to the FC. So the Happymodel VTX (Diamond and Whoop) do it the, IMO, easier way, where the cam output goes to the VTX first. Also other similar VTX that have the two plug system. So as to your question, my guess is cam is Video in and CC is video out, because the other two are power. But that would also suggest you have an analogue port for the VTX. If you do have a separate connector for the VTX, then ignore CC and wire the cam to cam and power to power. Ok I learned something new. CC is for the menu pin on the camera, the one you use to get OSD and change camera options, which i've never bothered doing so far. Your camera has no menu pin, so ignore that wire. Me aswell... I appreciate your thought process and direction. You got me looking & Thinking differently.... Thx • Posts: 5,856 Threads: 47 Likes Received: 2,775 in 2,237 posts Likes Given: 7,614 Joined: Jul 2019 Reputation: 97 Hi Cole, I am going to jump in here. Let me start by saying that I have had an assortment of experiences in working with analog video from simple video both with and without OSD to camera switching devices. I have also tried to mix video signals (didn't go well) and have used VTX units with a variety of input options. Pathfinder is correct, the blue wire is for Camera Control which allows the camera settings to be changed via the OSD. This only works if the camera has that option. Most of my cameras do not have that feature, so if the camera doesn't have it, then just ignore it. My thoughts on Camera and VTX wiring. It all depends on the VTX unit that you have. If the VTX only has one set of pads for video input, I wire this to the VTX output pads on the FC. Yes, the camera connects to the CAM input pads on the FC. What happens is that the video feed from the camera goes to the FC where the OSD information is added and then the video signal goes from the FC to the VTX where it is transmitted back to the goggles. With this type of VTX, you can connect the camera directly to the VTX, but if you also connect the FC signal to the same pad, it often distorts the video as the boards are not designed to mix input feeds. You can connect the camera just to the VTX, but then you don't have OSD info from the FC. As for trying to mix two video feeds; one from the camera and one from the FC (OSD), did not go well. Been there, done that,. So, now I only connect the camera to the FC when using this type of VTX. On the other hand, some VTX units have a set of pads for Camera input as well as FC input. I think that some of these VTX models might be designed to mix the camera feed with the OSD feed from the FC (not sure). In this scenario, you have options; connect the camera to the FC or directly to the VTX. Personally, I would not connect the camera to the FC and directly to the VTX at the same time. I would pick one way or the other. So, take a look at your VTX. Does it have a Camera input (pads or connector) that is separate from the FC connection? If there is only one connector or set of input pads on the VTX, then I would suggest connecting those to the VTX pads on the FC and the Camera to the Camera pads on the FC. Later, iFly Posts: 171 Threads: 31 Likes Received: 8 in 8 posts Likes Given: 37 Joined: Apr 2023 Reputation: 0 iFLY - Thanks for your input.. Greatly Appreciated... |
