17-Jun-2021, 09:40 PM
Hello everyone,
I'm stuck obviously. So lemme cut straight to the chase.
When I connect my Caddx Ant to the Eachine Nano V2 VTx (both brand new out of the box), I only get a black screen. OSD doesn't work either.
Now, the funny thing is, that the same Nano V2 works fine with all my other cams - same connector, same wires, same power source. The Ant works fine with my other VTx's. It's just the combo of the two that won't fire up. It's the second Ant I've tried with the same VTx, too.
I ruled out so far:
- PAL/NTSC - neither works
- Not enough power from VTx - I even tried separate power sources for VTx and Cam, 1S and 2S
- VTx works fine - I can unplug the Ant and plug in for example an Okkan or a Caddx Turbo SDR2 without even powering down instantly there's a nice and crisp picture in my goggles
- wrong frequency - nope, see above
- The cam itself - works fine with other VTx, including OSD
- I have an Eachine Goggles Two and an Eachine EV300D to my disposal and same results with both
Btw, the Ant+NanoV2 combo described herein is supposed to go onto my 1/27 scale drift car. So there's no FC inbetween the two and can be left out of the equation.
I really couldn't find anything even remotely similar online so I'm reaching out to you guys in hopes that you'll have an idea what else I could try
Thanks in advance
I ruled out so far:
Thanks in advance
