24-Feb-2023, 05:42 PM
Fundamentally the problem is I have an older flight controller (F3 Seriously Dodo - RMDO target), and trying to pair it with a modern 4-in-1 ESC (Skystars K060).
Trying to connect to it in Blheli_32 Suite I get an error:
"Found outdated 4way-interface revision v20.0.0.3
Please update "Betaflight" firmware to the most recent revision.
(4way-interface v20.0.0.5 or higher).
I was running Betaflight 3.5.7 on this board before, and tried updating to the last supported version, 4.0.6, and get the same exact error message. No more firmware updates available.
What options do I have? Can I flash and write to the ESC another method? Or is there something easier I can try with software or updates?
Not sure if it is important or not, but I only soldered up the ESC neutral and motor wires to the FC and skipped the current, vbat, and TX wires. It's just unneccesary for this build at this time.
Thank you for your help!
