Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 So my ancient computer that I was using for all my quad programs has basically died and so I finally replaced it. Is everyone using the latest version, or is it buggy? I assume I need to save my settings somehow and transfer to the new computer? Is this easier said than done? Thanks in advance. This new laptop will pretty much be exclusively used for quad and 3D printing. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 I went ahead and updated to 10.5.1, and I can't update firmware. I select my FC (LUXF4OSD) without issue. New version is loaded from online. But, when I try to flash I get, "Failed to open serial port" message. What did I miss? All drivers have been installed. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 You are in DFU when you try to flash? Also, I have noticed that there can sometimes be resource conflicts that will not allow BF to see the aircraft when it is plugged in. Luckily, I have a few laptops I can use. SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I don't have a lot of luck when I rely on BFC to automatically put the FC into bootloader mode aka DFU. Use the boot button on your FC. Hold it down when you plug in USB. You see DFU upper right corner. Or you can use CLI and type BL or DFU depending on your current firmware on your FC. Or if you have I believe is 3.3 or later, you can turn on expert mode and there is a toggle on the setup tab to put it into bootloader mode. Then flash while in DFU. • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 13-Apr-2019, 07:38 PM (This post was last modified: 13-Apr-2019, 07:39 PM by Deal-E-O.) Tried the expert mode route and no dice. When I try and holding the boot button and plugging in the USB, not only do I not get a DFU, it won't connect at all. I have to close Betaflight and re-open to get it to even connect. But, no DFU.... Deal I don't need a battery for this, do I? I didn't think so.... Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 Don't need a battery. You are probably missing Zadig driver. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 So either manually load Zadig or use driver fixer. https://impulserc.com/pages/downloads • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 Downloaded Zadig driver successfully. Already downloaded Impulse. All it does for me is ask me to connect ImpulseOSD hardware to the computer. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I think you download and install the wrong thing. If you properly install Zadig you don't need the Fixer. • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 I did the wrong one I guess, hehe. Once I get home I'll try again. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 Downloaded the correct one this time, thank you. I was able to use Expert Mode to enter DFU. I was able to update, and I'm pretty sure I restored my saved settings. Thanks for the guidance once again. You'll know if something didn't work, hehe. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 So, I was able to restore my settings under the restore settings tab. What about the CLI file that I saved? What do I do with that? Looks like my OSD settings are reset, but everything else seems good. Do I need to mess with the CLI file I saved? If so, how do I restore it? Do my questions even make sense, hehe? Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 If you had a bunch of OSD setting you wish to restore, copy all the lines with OSD in them from your DUMP file. Paste them into the CLI. You do not have to paste them one at a time, just CTRL-V the all of them at once. Finish off with a SAVE command and the FC should reboot. At this point, your OSD customization should be there again. I have a customized DIFF that includes OSD info, as well as radio and ports stuff. I just CTRL-C the whole file and CTRL-V it into the command line. It makes upgrading a snap! SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • Posts: 863 Threads: 43 Likes Received: 286 in 202 posts Likes Given: 12 Joined: Nov 2018 Reputation: 5 Thank you. Will do the old copy/paste trick when I get back home. Deal Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire. Tinyhawk, Tinyhawk S, and a DJI Spark. And projects on the bench.... • |
